Model 10 Crawler Serial Number
Showing 1 to 10 of 11 results
ArizonaWoodsWalker
Send a private message to ArizonaWoodsWalker
Just recently joined the Association. Last year, I purchased a well-worn Model 10, and have been slowly cosmetically restoring the Cat. This will hopefully preserve it for future restoration work. My question is about the serial number; where is it? I have checked the usual places. The original plate is missing from the back of the seat. On the transmission housing, just below the shift controls, there is no number. On the right side of the radiator, above the TEN, is stamped H B. In the right side of the engine block are K-28, CWC, T-33. I assume the last is a part number. Could this be a prototype tractor? Thank you for your help.
Sun, Jun 16, 2024 3:21 AM
steeltracs
Thank you received: 5
Check on the machined boss on the side of the radiator where the lights would mount. Some are stamped there.
Sun, Jun 16, 2024 12:31 PM
ArizonaWoodsWalker
Reply to steeltracs:
Thank you for the information. I will double check that area. The only thing I found were the letters HB. I will have to try and upload several pictures.
Sun, Jun 16, 2024 2:01 PM
Skinner
Reply to ArizonaWoodsWalker:
Check the left side of the engine block flat area where generator would mount. Approximately 2” x 3”
Flat with three holes threaded in it clean the paint off good I have found the number here before Skinner
Sun, Jun 16, 2024 9:45 PM
ArizonaWoodsWalker
Reply to Skinner:
Good advice. I will carefully clean off these areas. Ninety years of paint and grime will cover just about anything. Thanks again.
Sun, Jun 16, 2024 11:57 PM
willwingo
Thank you received: 6
FYI- the HB you are seeing is not "HB" but is a slightly stylized/ overlapped "HS" which was the logo for Harrison Steel. They were the foundry for Caterpillar.
Mon, Jun 17, 2024 12:31 AM
Thank you received: 27
Reply to willwingo:
[quote="willwingo post=257552 userid=815"]FYI- the HB you are seeing is not "HB" but is a slightly stylized/ overlapped "HS" which was the logo for Harrison Steel. They were the foundry for Caterpillar.
Good information. Had not heard that before. Thanks
 [/quote]
Mon, Jun 17, 2024 6:02 AM
ArizonaWoodsWalker
I finished cleaning the generator, and the two headlight mount areas. no indication of a serial number. The H is about one inch over the stylized 8 stamp. Assuming the H is for Holt. Clear coated those areas, so they can be double checked later. Next will again clean and check the inspection plate area next to the shift levers. I wonder if there are other Model 10 crawlers without a serial number? Thanks to everyone for their advice.
Fri, Jun 21, 2024 9:52 AM
Skinner
Yes, there was quite a few without serial numbers it’s like they just forgot to stamp them before they went out the end of the factory.
Fri, Jun 21, 2024 10:20 PM
ChrisE
Reply to Skinner:
I have seen a lot of old Fordson tractors without any serial numbers stamped in them. I guess it is a minor thing to do when you’re trying to move large quantities out the door in a short time to make the most of high demand.
Sat, Jun 22, 2024 9:15 AM
ArizonaWoodsWalker
Reply to ChrisE:
Interesting point; they aren't registered and the end users like farmers won't notice, you got yourself a new tractor. Makes it interesting as far as book keeping for the manufacturer. Looks like I will move on to another project for the crawler. It does have a power takeoff, I don't know if that was a standard item.
Sat, Jun 22, 2024 10:25 AM
