Missed it....D8
Missed it....D8
Showing 1 to 10 of 12 results
D6c10K
Send a private message to D6c10K
Fri, Dec 9, 2016 3:18 AM
kracked1
Been sitting a LONG time. Doesn't look all worn out.
Fri, Dec 9, 2016 4:22 AM
Thank you received: 140
Reply to kracked1:
Hi, D6c10k.
You mighta 'dodged a bullet' too. The inspection report says, "Engine could not be started." 'Cos of this, they could not do any of their normal low speed driving checks. Whether the engine could not be started 'cos of a pony motor issue or an issue with the diesel is not mentioned - or if it was, I missed it.
Fri, Dec 9, 2016 4:45 AM
kracked1
Hi, D6c10k.
Deas that also could mean the wet behind the ears inspector couldn't find the starter button.
Fri, Dec 9, 2016 5:35 AM
Reply to kracked1:
Hi, Kracked1.
Possibly. There were a few other things in the inspection report that indicated that they had not gone to much trouble.
Copied from site:
[b][i]Operational test is limited to low speed in a confined flat area without load. Differential interlocks, full transmission shifting and functionality of all drive axles cannot be fully verified. Inspector listens for abnormal noises, observes leaks and notes physical damage.
Description Rating Details
Transmission Not visible
Steering Clutches Not visible
Final Drives Not visible
Limited Function Check (Drivetrain-Track) The drivetrain could not be operationally checked. [/i][/b]
(2)
End copy.
Did they even bother to pull the transmission dipstick? Remove the inspection covers or drain plugs. Remove the filler plug or loosen the drain plug?
I suspect not.
Fri, Dec 9, 2016 5:52 AM
kracked1
Hi, Kracked1.
Copied from site:
(2)
End copy.
I suspect not.
Also said the CCU could not be inspected " cable and hook missing".
Fri, Dec 9, 2016 7:58 AM
Reply to kracked1:
Hi, Kracked1.
I missed that one but then I wasn't really looking hard either. Their comment on that says something about their inspection too.
Fri, Dec 9, 2016 9:37 AM
caterpillar13
Hi, Kracked1.
there is a D7G on there also , it runs and has new rails and shoes on it
Fri, Dec 9, 2016 12:08 PM
catsilver
Reply to caterpillar13:
Shame, its done hardly any work, although the idlers are at the end of their adjustment and the rails look a little low, the hex track nuts and spring washers tell me that they could be the original tracks, could be a good project machine at the right price.
Fri, Dec 9, 2016 4:24 PM
dpan
Send a private message to dpan
Reply to catsilver:
Are they the same model tractor, the current one [attachment=39328]IMG_0409.jpg[/attachment][attachment=39329]IMG_0841.JPG[/attachment] and the one Garlic Pete displayed a year ago. Imagine they are. That model working[attachment=39330]2015-7-15 Army Cat Pic.8.jpg[/attachment]
Sat, Dec 10, 2016 8:08 PM
Reply to dpan:
Hi, Dpan.
Two diff'rent ID plates - one is Air Force - 2U 17203 - and the other is Army Corps Of Engineers - 2U 15372.
I'm curious to know what make and model scraper that near one is in the last photo.
Sat, Dec 10, 2016 8:49 PM
