miss firing on cyinder 1. cat d2 5u (5U16172)
chruska
Send a private message to chruska
My cat d2 is misfiring on cylinder 1. I just did pistons and sleeves and had the head rebuilt. I also had all the injectors replace and the fuel pump for cylinder one remanufactured. im all out of ideas. is it possible that I must
work the engine under a little bit of load or something like that to break it in.
Tue, Apr 29, 2014 3:23 AM
While you do need to work the tractor hard to seat the rings as soon as possible, I doubt that will help on the problem with #1. I would move an injector from anothr cylinder that fires well and swap with the one in #1. Then see if the misfire stays with #1 or moves to #2 with the injector.
If it stays with #1, then the next step is to move another pump into the #1 spot on the injection pump housing and again, see if the misfire follows the pump you moved or stays with #1 cylinder.
If it still stays with #1, since you just overhauled the engine, I would lean more toward a lifter or camshaft problem in the injection pump housing, mis-adjusted valve clearance etc than the usual suspects of bad rings, piston or cylinder liner. It would be an 'eyeball' test, but also need to watch the rocker arms of #1 and compare the valve stroke etc between it and the rest. You can also check the camshaft lift with a dial indicator if there appears to be any discrepancy there.
Tue, Apr 29, 2014 5:46 AM
d9gdon
Besides what ccjersey said, double check your clearance on your decompression cam and rocker arm pad. The valve stem may be too long on #1 because of a pocketed valve or stem not at factory spec.
Tue, Apr 29, 2014 6:23 AM
Reply to d9gdon:
Check injection pump lifter height?
Tue, Apr 29, 2014 8:41 AM
jmvmopar
Was it missing before or just after you put all the parts in it?
Tue, Apr 29, 2014 10:40 AM
