milky clutch oil 17a cat
golddozer
Send a private message to golddozer
Changed my clutch oil recently due to water intrusion.Checked the condition after using it for about an hour and was surprised to see it white again.I didnt flush it i just allowed it to drain for about a week.Is it possible for coolant to leak into the clutch housing?maybe a frost plug at the back of the block?or a cracked blocked maybe.Coolant level seems to be the same.Has anyone ran into a similar problem?
Mon, Jun 15, 2015 5:41 AM
Thank you received: 39
There is nothing that would leak coolant in there. The flywheel housing is well below the cooling jackets and would require a major block crack to leak there. More than likely you did not get all the crap oil out of there. I'd put enough diesel in the housing to get a good wash while operating the tractor back and forth for a few minutes then dump and replace with correct oil. May take a couple of cycles to get it all cleaned up. Storing the tractor outside can contribute to the build up of condensate in the housing.
Mon, Jun 15, 2015 10:20 AM
