might not own D4 7U
might not own D4 7U
gunnarrenner
Send a private message to gunnarrenner
I reciently posted about possibly buying an d4 but wanted to figure out why the radiator is bubbeling up. After reading numerous posts I built a pressure tester and began testing cyls. Pulling the 3rd cyl injector nut the Pre.com. Started unscrewing same with 4th. I drained the coolant and was sure I found the problem (one of copper rings wasn't even in the pre com but pinched off to the side . I ordered the new o rings and copper rings cleaned and reinstalled the two loose pre coms. Then refilled ran then ... Still leaking into radiator! I pressure tested all cyls. (For 30 sec. or so) And they all hold. I am pretty lost know are there any suggestions? I read the water pump can suck air, is this at all likely if so how can you test.
BTY the symptoms can happen at any RPM but faster with more RPM. The coolant level rises untill it bubbles over and then frothy bubbles come up. No noticeable odor of exhaust.
Thanks.
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Fri, Apr 16, 2010 4:38 AM
SJ
Send a private message to SJ
It could be several things like a bad head gasket, a low liner or cracked head. Could be the seat damaged where the chamber wasn,t being sealed by the copper gasket.You may end up taking the head off and going through things step by step.
Fri, Apr 16, 2010 5:07 AM
gunnarrenner
Reply to SJ:
Would these things not show up with a pressure test. any suggestions on how long i should keep air on the cylinder.
thanks, again
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Fri, Apr 16, 2010 6:42 AM
hookblock
Send a private message to hookblock
Reply to gunnarrenner:
thanks, again
was the radiator pressure tested? I had a radiator that showed no signs of leaking but would foam up and push out of the radiator. Took the radiator in to get it tested and it was all pin holes. Ended up getting a new core.
Fri, Apr 16, 2010 7:09 AM
D4C Charlie
Send a private message to D4C Charlie
Reply to hookblock:
When the head on my D4C was cracked the coolant had many tiny bubbles come to the surface not big bubbles and didn't push coolant out. Got a reconditioned head from Cat 1500.00 ouch Charlie
Fri, Apr 16, 2010 7:35 AM
Willie
Reply to D4C Charlie:
How much water does it use how hot does it get and how soon does it staer frothing? Mine has done it since I got it 6 yrs ago but only when its running fast or workining the harder I work it the more it foams but in 5 yrs it hasnt used 2 gal. of water or got over 180 and the cause of mine is Im too lazy to tighten fan belt you can almost spin the fan when stopped so if yours acts like mine you may wanna chech fanbelt,waterpump impellers ohow clen the rad is inside and out
Fri, Apr 16, 2010 9:21 AM
Mike Meyer
Reply to Willie:
My RD4 does that too when I'm working her hard, but I know I've got a combustion related problem because the water goes black in an hour or two of working. Is your radiator water clear, or black?
Sat, Apr 17, 2010 4:44 AM
8C 361
Reply to Mike Meyer:
When you pressurize a cyl do bubbles appear in the radiator?
Sat, Apr 17, 2010 5:07 AM
gunnarrenner
Reply to 8C 361:
It starts rising and bubbling soon after starting. 30sec to a min. I dumps a half a quart or so every couple min. The coolant is not black or have any distinguishable smell or exhaust. No bubbles when pressure testing cyls.
On Sunday I am planning on starting it until it bubbles. Stop engine, remove fan belt, restart and see what happens. If no bubbles I assume I have a rad. Or water pump problem. If I still do have bubbles it should be in the engine. Of course watch temp.
Thanks for the help
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Sat, Apr 17, 2010 6:05 AM
