McCoy Special
McCoy Special
Showing 1 to 9 of 9 results
bruce oz
McCoy Special D8 2U , Is there any one that would like to guess if this is a real McCoy d8 ?
Thu, Aug 22, 2024 6:41 AM
Thank you received: 11
Hi, bruce oz.
Really need more photos of the rock guards and belly plates to be sure but I'd guess that it is not. Yes, it has had some work done on it but those rock guards on the tracks don't look genuine McCoy to me. If memory serves me rightly, the McCoy units also had heavier fenders to help with traction.
Thu, Aug 22, 2024 8:13 AM
LAOL
Send a private message to LAOL
Hi, bruce oz.
It certainly has some design similarities to my McCoy D4. What I noticed immediately was the blade design and rear pulley set up. Where I its located?
Thu, Aug 22, 2024 4:36 PM
Thank you received: 16
Reply to LAOL:
Looks more McCoy right to me from what I can see including just barely visible heavy side plate frame.
Thu, Aug 22, 2024 10:17 PM
bruce oz
McCoy Special D8
Tractor is located in the western district of Victoria Australia , it is said the one was inported to work on the snowy mountains scheme and ended up in area where it is now ,it is up for for sale / auction soon
https://en.wikipedia.org/wiki/Snowy_Mountains_Scheme
Fri, Aug 23, 2024 4:41 AM
D4Jim
Thank you received: 5
Reply to bruce oz:
McCoy Special D8
Here are some old pics and threads of a supposedly McCoy D8
There may be some confusion between the McCoy and the Hi-output D8
https://www.acmoc.org/bb/discussion-d72/8410-mc-coy-special?start=10
Restored as a member
Fri, Aug 23, 2024 8:48 AM
bruce oz
 hello Jim ,fitted with a D337 engine
 [attachment=77415]Capture.JPG[/attachment]
Fri, Aug 23, 2024 11:56 AM
D4Jim
Reply to bruce oz:
The memory I guess is the first to go. The only McCoy conversion I ever saw was about 50+ years ago and I remember it as having a single stack similar to the DW21. Don't recall seeing a roots on it so must have been the later turbo which i think came about in late 50's. I could be wrong but I remember the McCoy as having a single stack. I can remember it smoking like a steam engine.
The only reason I remember the McCoy designation as the guy told me about it when I mentioned the wider grousers on the Cat. In our area the D7 was the most common Cat.
That is not to say they maybe made some McCoy's with twin stacks.
We had a lot of IHC around here and they are the only ones I remember with the twin stacks.
What I am saying is I really don't know any more about the McCoy's than that.
Fri, Aug 23, 2024 1:30 PM
D4Jim
Reply to D4Jim:
found a helpful little gadget on when Cat engines were introduced.
https://www.timetoast.com/timelines/history-of-kitty-cat
Slide the little button along the bottom to any year.
Fri, Aug 23, 2024 1:42 PM
Reply to D4Jim:
Twin stacks was a change over offering for the DW20
Sat, Aug 24, 2024 4:48 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
