Maybe not Antique but old 3306 & powershift
Showing 1 to 10 of 14 results
Grizz
Send a private message to Grizz
I have a Pettibone loader that has had a 3306 pc turbo not aftercooled & a cat 4 speed power shift, transplanted in , The engine is loosing oil and the trans is gaining oil, The engine has a large cooler for the trans built on to the filter/engine oil cooler , I would imagine that this is coolant to oil??
Where could the oil be transferring , I will get the engine number soon
Thanks in advance
Thu, Aug 19, 2010 6:26 AM
bob
Send a private message to bob
If the trans oil is black change the rear crank seal.
Later Bob
Thu, Aug 19, 2010 6:54 AM
D6c10K
Send a private message to D6c10K
Reply to bob:
Later Bob
If it's like mine (3306 - D6c) there are 2 coolers on the side of the engine...one is engine oil-to-water and the other is trans oil-to-water so I don't think that's the problem. If it was you would see water in transmission.
Thu, Aug 19, 2010 9:11 AM
Thank you received: 93
Reply to D6c10K:
if the Trans pump is fitted to the flywheel housing with the engine oil lubed gear train it also could be the transmission pump input shaft seal leaking/cooked hard or fitted back to front. The seal lip faces out as it has to seal against pump suction head as the void behind the seal in the pump housing is connected to the suction line to drain off any trans pressure oil leakge past the pump shaft bearings.
Hope this helps.
Thu, Aug 19, 2010 10:38 AM
Reply to edb:
Hope this helps.
Hi edb,
Following along on this post and have a question.
No doubt there is a path there but if that seal was shot or reversed, wouldn't you draw air in or loose suction rather than have flow outward into the flywheel housing.....maybe I'm missing something.
Fri, Aug 20, 2010 12:21 AM
Mike Walsh
Hi edb,
Hi OM. Transmission pumps on the D8H and K were famous for transferring engine oil to the transmission when the seal went bad. Unfortunately its been too long since I've had one apart to explain why. The pumps I repaired/replaced gradually got worse which gave me time to recognize something was going on with the trans oil as it steadily got darker. I don't remember one that transferred large volumes of engine oil in a short period of time. Maybe I just got lucky before catastrophe settled in.
Fri, Aug 20, 2010 2:55 AM
Reply to Mike Walsh:
Hi Mike,
I suppose it's possible the D8 transmission pump could suck engine oil from the pto housing if the seal was bad, maybe some air too??
Seems a little different on the 3306 where the gear train is hanging on the housing in back of the flywheel. There would be some lube flying around from the engine supply as edb mentioned. What happens when the idler bearing goes bad and you loose oil control??
Fri, Aug 20, 2010 5:15 AM
Hi Mike,
Hi OM,
yes, depending on how shot the seal is you will draw air AND oil in from the 3306 engine oil lubed pump drive train---if that is what is fitted--- we are working with scant info from the inquirer so we are just trying to cover all bases for him as there may be other possible leakage paths apart from the engine rear seal.
Mike Walsh has covered it as it usually occured, slowly, and then one day they would not prime after a hot restart, if they got bad enough. An alert operator would hear the "marble in a peepot" sound on start up as the air went through the system and ask why.
Fri, Aug 20, 2010 8:05 AM
Grizz
Reply to edb:
Hi OM,
Thanks for the replies, I know nothing of this power units history before it went into the pettibone , I don't see an engine driven trans lube pump, So it is probably the rear main seal on the engine, I don't know how fast the oil is transfering , we just noticed it , the machine doesn't see much use an needs a lot of work . How much damage will the crank case oil cause if any ?? The way the machine is built the engine has to come out to pull the pan so it is a fairly large head ache , and once you get insidem where do you stop??:noidea:
Fri, Aug 20, 2010 10:18 AM
Reply to Grizz:
Can you post the engine serial and arrangement number?
Also the vintage of the Pettibone unit.
Fri, Aug 20, 2010 12:17 PM
Grizz
3N 89579, no Arrangement number the tag is long gone . The Pettibone is a '78
Super 20 carry lift, origonally equiped with a 4-71 detroit and a allison/twindisc
power shift/ transfer case
Sun, Aug 22, 2010 3:55 AM
