Manual Priming Pump
Manual Priming Pump
n7gxz
Send a private message to n7gxz
Is any one familur with this type of manual priming pump?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260411085760
I'm working on converting my D2 to a direct electric start and I came across this pump. Would it mount between the tank and the transfer pump?
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Mon, Jun 22, 2009 4:31 AM
I just got one of those myself (from Tornado parts, Medina.Ohio) to experiment with but haven't got around to messing with it yet. They are a very common pump for the engines after the "U" models. The one thing I would want to incorporate is that it take suction from at least primary filtered fuel so I have selected a primary filter to use where I can tap in this pump. The other thing I'm a little concerned about is that this pump is a very low volume output compared to the ones used on the D311/D315/D318 engines so it may take a lot of pumping to get the job done.
Mon, Jun 22, 2009 7:39 AM
n7gxz
Thanks OM. I had already added a filter/water sep between the tank and the transfer pump back when I got the D2 12 years ago. What size fittings does this pump have on it?
Kevin
Mon, Jun 22, 2009 8:04 AM
Reply to n7gxz:
Kevin
In/out is 1/8 inch NPT.
Mon, Jun 22, 2009 8:26 AM
All ya need to do is switch the compression lever to start and easily turn the engine over to prime the system.
Mon, Jun 22, 2009 8:44 AM
