Magnito Recharge?
Magnito Recharge?
Showing 1 to 10 of 23 results
lrolla
Send a private message to lrolla
The Pony motor saga continues. Thanks to the wisdom of the forum I think I'm past the carburetor adjustment and know what I'm doing now. Ha Ha.
Here are the new symptoms. Attempting to clear out the over fueled cylinder I removed a plug from one side and disconnected the spark plug wire from the plug. I then turned over the pony to flush out the cylinder and the pony started right away on one cylinder. I put the plug back in, tried to start it .... nothing. I then removed the other plug and wire and it started again, but this time on the other cylinder. I put the plug back in and tried to start it ... nothing. Seems like the magnito doesn't have enough juice to fire both plugs. Does this make sense? I can get spark from both sides with the plugs out but it lacks the spark when assembled. I've been told that a magnito could need to be recharged. Does this sound like the case?
Thanks all for the help.
Larry
Larry Rolla
Sun, Nov 28, 2010 4:05 AM
SpragueM
Larry,
When mine does that, it usually means I need to replace the plugs. I'm not ruling out a weak coil, but the plugs may be fouled. Another trick is to get the wire so it leaves a small gap between the plug and it's self (not on all the way).
This will create a hotter spark, but makes the coil work harder. On a fouled plug it makes enough juice to jump the gap.
Matt
Sun, Nov 28, 2010 6:12 AM
Reply to SpragueM:
Larry,
Matt
What/who's plugs are you using.
Why are you pulling the plugs to purge the cylinders....that's what the drain cocks (on the bottom) are for, otherwise it's still possible to have liquid fuel or oil laying in the bottom of the cylinder.
Sun, Nov 28, 2010 6:20 AM
terrywelch_archive
I have had plugs that fire fine out side the cylinder and when there is a little back pressure will not fire. Most the time it is one brand. You might want to try a different brand.
Terry
Sun, Nov 28, 2010 7:03 AM
STEPHEN
Reply to terrywelch_archive:
Terry
Just leaving one plug out doesn't help the mag/coil, it only could hurt it by building up a potential that isn't dissapated. Some of the Eisemann mags had a internal gap so the energy would be relieved if a plug wire came loose. I suppose todays better quality windings would lessen that trouble. Still, the thought that the coil would have enough to fire one but not both seems suspect. would a bad condenser do that? You didn't say what brand of mag you are using, AB, Wico, or Eisemann. In my experiance, the AB mags are almost foolproof.
Sun, Nov 28, 2010 7:52 AM
zootownjeepguy
Reply to STEPHEN:
I have found that Champion spark plugs, or any other plug with a cadmium plated base seem to foul much faster in the older low compression engines than plugs such as AC, Autolite or others with a Black Oxide finished base. I don't know why, but they last longer. I once had a 1937 John Deere B and those $9 apiece Champion W14's would last about 2 tractor shows before they fouled. I switched to AC plugs (same heat range as the W14) and they lasted a full summer of tractor shows and putting around the neighborhood.
If you are not getting spark from one side of your magneto, I'd check the cap inside for carbon tracks, could be shorting internally.
Rich Salvaggio
D2 5U9917
Sun, Nov 28, 2010 8:15 AM
hiwide15
Send a private message to hiwide15
Reply to zootownjeepguy:
just a couple more thoughts , make sure the wire are real wire to the plugs and that they connect good at all places. magnetoes donot like carbon wire , then make sure the spark will jump 3/16 inch at crank speed, if not it will start hard at best, then use autolite plugs , the rest of the new ones are junk, nkg may also work. then if it has fuel and a little compression it will start on the first pull .Old rule is if coil fails it will fail when it is warmed up good, a condenser will somtimes start and run for a few seconds or only fire one time and not work any more , if in doubt replace it. hope this helps , ron meeder
Sun, Nov 28, 2010 9:12 AM
lrolla
Reply to hiwide15:
Sorry for the lack of details.
Mag: AB
Plugs: New from Cat. Not sure what brand. I'll have to check.
Wires: New from Cat.
Condenser, points, and brushes all new.
I had the pony running a couple days back while I was working on the carb and it was running ok and then all of sudden died like someone threw the kill switch. Has not run the same since that moment.
I can't believe that both plugs went bad at the same time. After reading the responses I'm leaning more towards the condenser. I still have the old parts and will have to start the swap out process.
Is there a way to test the condenser?
Thanks for the the advice and wisdom.
Larry
Larry Rolla
Sun, Nov 28, 2010 10:01 AM
lrolla
[quote="Old Magnet"]What/who's plugs are you using.
Why are you pulling the plugs to purge the cylinders....that's what the drain cocks (on the bottom) are for, otherwise it's still possible to have liquid fuel or oil laying in the bottom of the cylinder.[/quote]
OM, Rookie at the wheel. I had the drain cocks open too but wanted to see if the plugs were soaked. While I had it out I turned over the motor to purge the cylinder. As it turned out, it's taken me down the path of the problem. Rookie luck.
Larry Rolla
Sun, Nov 28, 2010 10:08 AM
Reply to lrolla:
Rig up a 6v battery test circuit light and leads. Touch one lead to the condenser metal jacket and the other to the center post. If the light gives a short flash it is ok. If it flickers its leaking. If the light stays on it's shorted.
If the coil fires one plug it's probably ok. Pretty rare to have them require remagnatizing. Can't be to bad if it has recently run.
I have had Champion plugs come dead as new. Also intermitent firing under load.
I use the NGK 6 or the Autolite 386.
Be sure the mag has a good ground.
Sun, Nov 28, 2010 12:15 PM
zootownjeepguy
If your mag was working fine and then died suddenly with all new parts inside, I'd check the point gap. I once forgot to tighten the point screws in a mag (they were snug for setting the gap) and they loosened up and closed while the engine was running. Hopefully you don't make the same mistakes I make (My mistakes are copyrighted, I could take legal action).😆
Rich Salvaggio
D2 5U9917
Mon, Nov 29, 2010 8:08 AM
