Magneto Timing Question
d50dave
Send a private message to d50dave
I have a gas 50 Cat and an Allis K that are both hard to start and then run really well once they're started. Both mags have really hot spark - probably jump 3/16 to 1/4 inch out in the open. One thing that seems to be common to both of them is that the impulse coupler seems to retard the timing more than the other mag ignition tractors I have. I can't believe the basic timing is that far off because they both run really well under a heavy load like plowing. Both engines will fire kind of weakly when the impulse is clicking and can't quite get going, but if they do start they both settle into nice running. Do different mags have different amounts of timing retard to the impulse coupler? Another common thing is they both need to be really rich to fire at all but they seem to burn all that gas out within a couple seconds and don't act flooded. Thanks for any help.
Dave
Sat, Jun 4, 2011 1:47 AM
u-joint
Send a private message to u-joint
an impulse does not retard timing. while the mag is being spun slow your impulse will hold your mags rotor from spinning a while before TDC and let it go just before TDC. this quick action is needed while cranking slow to keep the points working accurate. if you had no impulse while cranking by hand, your ignition timing would be erratic due to the points opening so slow.
you might try checking your cap and rotor rotors position when you are on a cylinders TDC. your rotor should be straight accross from the caps post when your points are open. most mags point plate can be moved to adjust this.
Sat, Jun 4, 2011 12:11 PM
Thank you received: 20
Reply to u-joint:
Those are some pretty generic questions to cover all mags.....but in general
the AB & Eisemann mags are fixed timing (no advance) and the retard angle is fixed at 30 degrees.
The main purpose for the "impulse" is to intensify the ignition spark at low cranking speeds to aid in starting while minimizing the chance of back fire.
This is done by retarding the spark, stopping the rotor while winding up a spring and having the cam release the spring and rotor at the correct time to provide the intensified spark. Once started the mechanism returns the timing to normal at about 180 rpm.
So if your mags are operating normally other than at cranking, you need to look into the condition of the impulse mechanism, they do wear, stick and can get generally buggered up. They are also kind of touchy, depending on gravity, friction and sliding operation.
A weak impulse spring or fouled spring compartment can affect operation.
Whether it be AB, Eisemann or others about the only adjustment control is the setting of the "E" distance or "edge distance" on the AB or the timing of the induction rotor to the breaker plate on the Eisemann.
The "E" distance on the AB is the distance between the pole shoe and the edge of the magnet rotor.
If the distancing is off it will cause hard starting and loss of power.
Sat, Jun 4, 2011 10:55 PM
d50dave
Old Magnet,
Thanks for the reply. I understand what you mean about the rotor cutting through the magnetic field at the proper time when the points open (since both mags are fixed magnet and not rotating magnet). I haven't checked the point timing with respect to the rotor position but I can't believe it's too far off since it produces such a good spark. Back to my original question about impulse retard, you mentioned that most(all?) mags were set at 30 degrees. Have you ever seem one get worn such that the retard angle becomes greater that 30 deg.? I will try to measure the crank angle past TDC when the impulse clicks and compare to point opening crank angle with no impulse delay.
Dave
Sun, Jun 5, 2011 2:27 AM
Reply to d50dave:
Old Magnet,
Dave
In general I'm referring to the AB & Eisemann mags on Cat products. Through normal use they don't seem to get more than a couple of degrees off.....but through improper assembly and mixing of parts they can wind up most anywhere as there are many combos and interchangeable parts. What do you know of the history of your mags?
Just as an adder...good spark on the AB is considered to be 9mm, just under 3/8 in. with strong blue arc.
Sun, Jun 5, 2011 3:37 AM
