Magneto repair
Magneto repair
Showing 1 to 6 of 6 results
Flathead
Send a private message to Flathead
Hi, I’m in Northern California and I’m trying to find someone who will repair magnetos. I was using Florin Tractor. Thanks in advance
Fri, Jun 2, 2023 2:08 AM
d4angelo
Thank you received: 8
I have used Mainly Magnetos in the state of Maine with good results.
Fri, Jun 2, 2023 2:42 AM
d4angelo
Reply to d4angelo:
Chad Enyeart at Antique Crawler Parts is an ACMOC member and is a magneto specialist. 1-307-760-8483
Fri, Jun 2, 2023 2:45 AM
Reply to d4angelo:
`Marks Magneto 860-537-0376 " Not just pretty on the outside either, he does quality work!
Fri, Jun 2, 2023 2:55 AM
Thank you received: 55
for those down under i have found zochy's magneto repairs. chris does good work. he doesnt really do the make em shiny bit but gets them working properly and reasonably priced too.
he is at harrington in new south wales. his postal address is po box 118 Harrington NSW 2427 Phone 0424011767
Fri, Jun 2, 2023 7:20 AM
Thank you received: 289
Reply to trainzkid88:
Where in NorCal approximately? Canevari Bros. in Woodland, CA has done some for me in the past; there is supposed to be a shop on Auburn Blvd. in Sacramento that does them as well. JM
Fri, Jun 2, 2023 7:37 AM
Flathead
Thank you, I’m on the Mendocino coast. Thanks again.
Fri, Jun 2, 2023 10:05 AM
