Magneto question
Magneto question
Showing 1 to 10 of 14 results
D6Rick
Send a private message to D6Rick
Whats the difference between an American Bosch MJK 4/2 360 B-410 and a MJK 4/2 360 C-410. The 360-B was on a D6 9U parts machine I bought several years ago, it has an impulse problem I'm tring to fix. The D6 I'm working on now has a WICO mag on it with a Cat part # 4S6470. My parts book doesn't show a WICO mag in it. Did the D6 9U's come with WICO mags at some point?
Thanks.
Fri, Feb 1, 2008 10:21 AM
KidNV
Send a private message to KidNV
Rick, maybe this will help some.. Dont know about the Wico though..
Magneto Numbers-----------------------
Here is a listing of MJK starting engine magnetos that should help keep someone from buying the wrong magneto. You will need a parts book for the machine you are wanting to buy a magneto for and procede from there. On any areas I have listed that says "should be", I did not have a listing for that particular vintage of MJK magneto listed in my American Bosch book and had to go to a latter vintage of magneto with the same numbers. Example: MJK 4A 409 Caterpillar part # 3F8575, I did show an A vintage of magneto, but I showed a MJK 4C 409 magneto that usually means it supercedes the previous letter vintage. I can not state that I have made no errors, this took some time (too much time).
Craig
The number in the top row is the Caterpillar part number.
'=degrees
The right hand most number listed in the second row tells the rotation of the magneto when looking directly at the impulse hub or drive gear. American Bosch had a direction of rotation indentifier built into their application numbering system. Even numbers are clockwise (cw) and odd numbers are counter clockwise (ccw).
flange mounting = mounting flange bolts are vertical
horizontal flange mounting = mounting flange bolts are horizontal
I did not research which flange mounted magnetos stand on end. Any that do have to have spring loaded impulse weights so they will latch up due to the fact they can not fall into place by gravity.
1H3572
MJK 4/2 360' C417
ccw / horizontal flange mounting
3F8569
MJK 4A 408
cw / should be a horizontal flange mounting
3F8570
MJK 4/2 360' A408
3F8571
MJK 4A 41
3F8572
MJK 4/2 360' A47
3F8573
MJK 4A 313
ccw / flange mounting
3F8574
MJK 4/2 180' A311Y
3F8575
MJK 4A 409
ccw / appears to be horizontal flange mounting
3F8576
MJK 4/2 360' A409
4F8678
MJK 4/2 360' A410
4F8679
MJK 4A 410
5F7489
MJK 4B 408
5F7490
MJK 4/2 360' B408
5F7491
MJK 4B 41
ccw / should be a horizontal flange mounting
5F7492
MJK 4/2 360' B47
5F7493
MJK 4B 313
5F7494
MJK 4/2 180' B311
5F7495
MJK 4B 409
5F7496
MJK 4/2 360' B409
5F7497
MJK 4/2 360' B410
5F7498
MJK 4B 410
6F1082
MJK 4/2 180' B107
ccw / should be base mounting
6F1083
MJK 4/2 180' B109
6F1084
MJK 4/2 360' B48
7F6532
MJK 4/2 180' C313
7F6533
MJK 4/2 360' C412
7F9922
MJK 4/2 180' C107
ccw / base mounted
7F9923
MJK 4/2 180' C109
ccw / base mounted
7F9924
MJK 4/2 360' C48
7F9929
MJK 4C 408
7F9930
MJK 4/2 360' C408
7F9931
MJK 4C 41
7F9932
MJK 4/2 360' C47
7F9933
MJK 4C 313
7F9934
MJK 4/2 180' C311
7F9935
MJK 4C 409
7F9936
MJK 4/2 360' C409
7F9937
MJK 4/2 360' C410
7F9938
MJK 4C 410
8F5871
MJK 4/2 360' C411
9F1165
MJK 4/2 180' C319
9F2513
MJK 4/2 360' C49
9F4475
MJK 4/2 360' C45
9F5113
MJK 4/2 360' C420
Fri, Feb 1, 2008 10:49 AM
My parts book has the 4S6470 as the "complete magneto" to order. All the Bosch versions are listed as "individual parts only" or something to that effect.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timešŸ˜„
Fri, Feb 1, 2008 10:54 AM
Thank you received: 52
American Bosch mags came in A, B, C, D models.....all pretty much alike.
I show the 410 models as having a part number ICK 2A4-30 deg. impulse coupling assy and assigned to the industrial engine D6
The 408 models have a ICK 2A2-30 deg. impulse coupling assy and are designated for the D6 tractor.
Yes, towards the end of the D6"U" run they switched to the WICO mags and used them on into the D6B production. (To me they are not built as well as the AB units.)
Fri, Feb 1, 2008 10:56 AM
D6Rick
Thanks guys for the answers and information and I appreciate all the mag numbers you put together KidNV. Nice job! That will come in handy. I was able to fix my impulse problem by robbing the weights and plate from a six cylinder Bosch I had laying around that came off a MM power unit. I was surprised they used the same parts. Thanks again, Rick
Fri, Feb 29, 2008 10:06 AM
tarquj
Send a private message to tarquj
Reply to D6Rick:
Ok,
So Pulled the cap off my magneto MJK 4/2 360C-47 and the pulled the rotor off. It disintegrated in my hand. I’m thinking this is the source of my pony engine problems. Now the rest of the rotor (Brass piece) seems seized in the shaft. I pulled on it and pulled the whole gear shaft out. I’m worried that there was a snap ring and washer on the back of the shaft that popped off and is now lost inside the mag, so far have not found it. It could be stuck to the magnets inside the.
I also have a MJK 4/2 180 A311 with all good parts.
Question: Can I swap back flanges, drive gear, points, etc. and run the 4/2 180 clock wise or will it not spark rotating the opposite way, maybe due to the windings in the armature?
Thanks in advance!
Jeff T
Mon, Jun 28, 2010 7:07 PM
tarquj
Reply to tarquj:
Ok,
Thanks in advance!
Jeff T
I misread above. Since both part numbers are odd, they are both ccw, so there should be no roation issues.
So the real questions are:
1. Am I missing a retaining ring/washer?
2. Can I swap rear flangs and use the other mag?
3. Timing for reinstall?
Thanks again,
Jeff T
Mon, Jun 28, 2010 7:47 PM
bruce oz
Thank you received: 23
Reply to tarquj:
Thanks again,
Jeff T
hello tarquj ,the sheet i have for the Bosch magneto says all the parts are the same expect parts 2,3,4B and 67B,
MJK4/2 360 is clockwise rotation and MJk4/2 180 anti clock wise rotation ,
http://img685.yfrog.com/gal.php?g=79698014.jpg
bruce oz
Tue, Jun 29, 2010 5:28 AM
tarquj
Reply to bruce oz:
bruce oz
Hi Bruce, thanks for the reply,
I didn't get a chance to tinker with the Mags last night, but I'll try again tonight.
Are you sure about this? this contradicts what kidNV states above although he also caveats his list by "I can not state that I have made no errors, this took some time (too much time). " But, according to this:
-MJK 4/2 180' A311Y ccw / flange mounting
-MJK 4/2 360' C47 ccw / horizontal flange mounting
This supports my theory that only the mounting flanges are different (with a few minor casting changes, etc.), once flanges swapped I should be good to go... the 180' vs 360' looks to be the flange designation while the last numeric character odd vs even correlates to ccw vs cw rotation. This is consistent through the entire list.
One more thing about the 180 mag, we used the cap from the 180 on the 360 years ago. We had to cross the plug wires to get it to run, but couldn't remember if that was the stock config or if it was the difference in mags causing the need for cross wiring. I'm wondering if that is another difference in 180 vs 360... Another note, the 180' came from an earlier dozer (no clue about serial number, was in a bone yard) than the 955 which was running with the 360'.
Jeff T
Tue, Jun 29, 2010 6:33 PM
bruce oz
Reply to tarquj:
Jeff T
hello tarquj sorry for the miss info,i did miss reading the c47 when i was reading the mag infošŸ˜–mokin:.kidNV info is better than mine .it is hard picking up mag info with so many models fitted to the cats ,in the link it looks like the flanges are diff part like you say .bruce oz
Wed, Jun 30, 2010 3:31 AM
tarquj
Reply to bruce oz:
No worries Bruce, I appreciate the feedback.
Any ideas on how the 180' mag will react when I bolt it into my machine? I am going to try it and see anyway, but it would be nice to know ahead if i have to debug.
Either way, I note my results here.
jt
Wed, Jun 30, 2010 6:25 PM
