magneto interchange
magneto interchange
Showing 1 to 6 of 6 results
kiwicats
Send a private message to kiwicats
hi folks.
i have an Eiseman magneto # RC2Q which i understand came from a D8 8R. Can i use this on my Diesel 35?
The Diesel 35 was originally fitted with a GV2Q (from the parts book).
Thanks.
peter.
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
D4 (4g,7j,2t,5t,6u,7u)
Diesel 35
D8 (8r)
Sun, Mar 20, 2011 11:42 AM
dick
Send a private message to dick
No, the 8R has a vertical flange mount and your D35 has an inverted base mount mag.
Sun, Mar 20, 2011 10:19 PM
kiwicats
Reply to dick:
thanks.
i see that the RC mag does have mounting holes in its base- presumeably they use the same casting for vertical/horizontal/ base mounting...
so if i can live with the vertical flange being 'redundant', will my mag do the job???
thanks.
peter
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
Diesel 35
D8 (8r)
Mon, Mar 21, 2011 3:01 AM
SpragueM
Reply to kiwicats:
thanks.
thanks.
peter
I just looked at the magneto on my RD6 and it is an RC2Q. So you should be able to use yours on the 35 diesel.
Matt
Mon, Mar 21, 2011 7:01 AM
kiwicats
Reply to SpragueM:
Matt
thanks matt.
does your mag still have a redundant vertical mounting flange on the impulse end and does it attach via 4 bolts in the base (upside down)?
peter
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
Diesel 35
D8 (8r)
Mon, Mar 21, 2011 10:57 AM
SpragueM
Reply to kiwicats:
thanks matt.
peter
No redundant flange mount, only the four bolts that hold it on upside down.
Matt
Tue, Mar 22, 2011 5:36 AM
kiwicats
Reply to SpragueM:
Matt
mmm...
tks.
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
Diesel 35
D8 (8r)
Tue, Mar 22, 2011 9:52 AM
| Kingaroy, Queensland
