Magneto Guru Help - Cat 22
Dave Reed
Send a private message to Dave Reed
I bought a running 22 that came with a WICO XH 1344 mag. I have not been able to drum up much info on the 1344 mag.
After reading several other mag-related threads here (thanks) I learned that the WICO XH 184 is a pretty good alternative to the old Eisemann mags, and I was able to pick up one of those up reasonable.
My question is this - is the XH 1344 also an OK substitute or should I change over to the XH 184?
Also, any advice on testing one myself, or am I better off to ship it off to someone who knows what they are doing?
Appreciate your help😊
Sat, Mar 28, 2009 10:30 PM
Lance Jones
Briefly it should be OK to use either , I am no expert but play around with them a bit. If it throws an 8-10 ml blue spark then it should be OK. If you don't have access to a test bench , then carefully remove impulse and ,place in a vice and run it up with electric drill . Just make sure your new one has the correct rotation .Good luck
Sun, Mar 29, 2009 2:29 AM
Dave Reed
Thanks for your help Lance......Dave😊
Mon, Mar 30, 2009 3:13 AM
| ā€œDe Domelaarā€ Gebr .V.d. Heiden Domelaarsweg 3 7475 MARKELO Netherlands
