Mag Spark
Mag Spark
Showing 1 to 10 of 13 results
fraser05
Send a private message to fraser05
I have two bosh mags on the bench and both seem to have the same spark which is very little. Only 1 mm spark from coil right to the casing. Seems to not be enough to make it though the whole system, no spark at all through a spark plug. I'm spinning it full speed on a cordless drill. I have three rotors they all seem to have a fairly strong magnetism. Should I pull the coils out and try baking them? I have had the motor running on both of these mags in the last two months but now nothing. Any ideas would be appreciated. Thanks
Sun, Jul 16, 2017 4:37 AM
Replace condenser, lightly sand, NOT file points and reset gap. Points should not be burnt or pitted and contact evenly.
Sun, Jul 16, 2017 5:35 AM
Have you tried changing the gap on the points? What are you set on now? I think if you are getting any spark, the points are working. The condenser(capacitor) seems like a good first thing to try changing out. I cannot see why you would need to remove the coil from the mag to dry it out if you want to try. Just remove the cap so it can breathe.
Sun, Jul 16, 2017 9:01 AM
Thank you received: 51
Easy enough to check if you have a multimeter.
A probe from the spark plug connector to ground should read about 6200 ohm on the Bosch Mag. 3000 to 15000 ohm should still work. Any higher is a poor connection.
Check condenser with ohm meter or capacitance check.
With ohm function probing from lead to casing should show reading go to infinity as condenser charges.
or 0.024 microfarad if you have capacitance check function on the meter. 0.015 - 0.030 microfarad should still work.
Sun, Jul 16, 2017 9:40 AM
fraser05
I've cleaned and sanded the points several times and tried different gaps from .014 to .020. I took a condenser out of my pickup and put in it. It seemed to help a little about a 1/4" spark from the coil to the casing. I've ohmed the coils one 5.7 k the other 6.2 k. The points are less than 1. No short to ground. One distributor cap is much higher. Must be broke inside. The other is less than 1 from brush to prong. I haven't tried to ohm everything assembled but will. Distributor rotor is also less than 1 and 6m to ground.
What reading should you get from the wire on the grounding post from the coil to ground?
Sun, Jul 16, 2017 10:30 AM
Reply to fraser05:
I would expect straight continuity (no resistance) from grounding post to ground.
Primary coil wire to ground (larger wire, fewer turns) should also have very low resistance.
Sun, Jul 16, 2017 1:34 PM
fraser05
Hold on a second. If that wire is already grounded then how does the kill switch do any good? What is the point of isolating the grounding post if the wire connected is to it from the coil is grounded?
Does anyone have a tech manual on these with a spec sheet? The cat books don't say much other than timing.
Sun, Jul 16, 2017 11:53 PM
Reply to fraser05:
There just doesn't seem to be a useful trouble shooting manual out there. Even AB's own manual is pretty limited. About all they say for sure is the cut off point for the coil secondary is 6200 ohm.
Attached basic magneto wiring diagram.
Mon, Jul 17, 2017 1:46 AM
Soapy
Send a private message to Soapy
Reply to fraser05:
[quote="fraser05"]Hold on a second. If that wire is already grounded then how does the kill switch do any good? What is the point of isolating the grounding post if the wire connected is to it from the coil is grounded?
Does anyone have a tech manual on these with a spec sheet? The cat books don't say much other than timing.[/quote]
If the spark is yellow, change the condenser. Should be blue. They will run with a yellow spark, but a real bear to get running. spark plug gap on all magneto fired engines should be 25thousands. Napa condenser will work on many applications #rr-175 If yours has the odd mount bracket, carefully drill out the spot welds, tin the bracket with solder, and after scraping the side of the new condenser, solder the bracket to it being careful with the heat applied, and cool immediately. Cap checkers are available at W.W. Granger a bit north of $65
Mon, Jul 17, 2017 2:52 AM
Reply to Soapy:
Per AB spec. point gap should be 0.014 - 0.018"
Should jump a 9mm spark gap with rotor turning 200 rpm.
Mon, Jul 17, 2017 3:16 AM
fraser05
After exasperating all things I could think of I was left with only trying turning the mag the other direction. I was tuning it clockwise looking at the gear in order to not spin the nut off with an impact gun. Tried turning the other way worked great. Don't know what was wrong in the first place that finally made me pull it back off but glad to say I've had it started twice and is running smoothly. Thanks for everyone's suggestions I'm sure it will come in handy for me having the info and other readers.
Mon, Jul 17, 2017 10:13 AM
