Lubrication ?'s about my early 50's Cat d4 HT4
JAKEcatHT4
Send a private message to JAKEcatHT4
While puttin grease to the fittings i came across a dipstick near the base on my steering levers. I pulled it to find only a smidge. Is this my gearbox dipstick? I dont have any maintenance manuals. Is the huge hex pocket screw plug the fill location? And can I add the sae 30wt there?.. Also Do I have a wet clutch?
Sun, Aug 8, 2010 9:35 AM
ol Grump
Jake,
The dipstick is for the tranny. .if you change oil it'll take around 6 gallons. The large hex plug is the fill hole and I'd use 80W-90 rather than 30 wt oil. As far as a wet clutch, you'd either have to post a serial number or just remove the access cover and take a look.
Sun, Aug 8, 2010 8:20 PM
Reply to ol Grump:
Jake,
Normally the HT4 is to early to have an oil clutch. If it did there would be another dipstick up by your right foot and a big fill plug in the clutch inspection cover.
Sun, Aug 8, 2010 11:33 PM
JAKEcatHT4
hey.. thanks for the info.. Probably wont change the oil , but I'd like to see a good amount on the dipstick.. 80w it is ! ...Now heres one for you. On my final drives do i fill those with 80w and how do i check the levels?
Thu, Aug 12, 2010 8:32 AM
ag-mike
Reply to JAKEcatHT4:
theres a sight plug on theside of trans so u dont have to keep reaching for the stick.
Thu, Aug 12, 2010 9:11 AM
ol Grump
Reply to ag-mike:
Jake,
For filling the finals, you just take the countersunk hex fill plugs at the rear of the finals out and fill 'til the level of the 80W90 is even with the top of the hole, reinstall the plugs and you're good to go.
Thu, Aug 12, 2010 8:32 PM
