Lube chart for Cat 22
Showing 1 to 10 of 12 results
hidesertman
Send a private message to hidesertman
Hi, was looking for a copy of this chart from the operator manual. One website I found it, is missing this important info! Thanks for your help.
Mike
Thu, Nov 30, 2017 2:11 AM
ianoz
Welcome to the forum Mike .
I do have a lub chart ,But i have just got a new computer , and hooking up the scanner , is a bit over the top of my head . But hopefully a refreshed post on here may shake up some one that can help.
Fri, Dec 1, 2017 7:14 PM
Reply to ianoz:
There is that fellow with the CAT 22 webpage and I seem to remember that he posted the Chart Ianoz is referring too?
I am drawing a blank still today on his name?
Fri, Dec 1, 2017 7:20 PM
STEPHEN
Reply to drujinin:
[quote="drujinin"]There is that fellow with the CAT 22 webpage and I seem to remember that he posted the Chart Ianoz is referring too?
I am drawing a blank still today on his name?[/quote]
Southern Cross something or other??
Fri, Dec 1, 2017 8:59 PM
Thank you received: 99
Reply to drujinin:
Hi, Highdesertman.
Welkum too ther 4um.
Here are a couple of links that may - or may not - help.
http://www.angelfire.com/home/cat22/
http://www.angelfire.com/home/cat22/book/manual.html
Fri, Dec 1, 2017 9:04 PM
biggastractor
Hi, Highdesertman.
I have an electronic version of the 22 operator and parts manual. if you want them just PM me. Good Luck
Biggastractor
Fri, Dec 1, 2017 9:12 PM
ianoz
Reply to drujinin:
Bruce OZ had a Cat 22 site , Not sure it it is still operational . Bruce used to have a link to it as his By line . The Link Deas put up has the instructions . But not the fold out Lub Guide . Which has the service hour checks and other handy infomation .
Fri, Dec 1, 2017 10:49 PM
Peter C
Send a private message to Peter C
Reply to ianoz:
This might help:
[attachment=45843]20160625_110436.jpg[/attachment] [attachment=45842]20160625_110445.jpg[/attachment] [attachment=45841]20160627_192645.jpg[/attachment]
Pete
Sat, Dec 2, 2017 12:19 AM
hidesertman
Reply to Peter C:
This might help:
Pete
[quote="Peter C"]This might help:
Pete[/quote]
Yes Pete, This is what I'm looking for, it helps a lot, but a little tough to see the details of the fill and drain points in the scanned image...
Mike
Sat, Dec 2, 2017 1:07 AM
hidesertman
Reply to ianoz:
[quote="ianoz"]Welcome to the forum Mike .
I do have a lub chart ,But i have just got a new computer , and hooking up the scanner , is a bit over the top of my head . But hopefully a refreshed post on here may shake up some one that can help.[/quote]
If its a newer scanner, it should be just plug-n-play from USB port, might need to download and install the scanner driver from its website, if your computer doesn't automatically find it.
Mike
Sat, Dec 2, 2017 1:36 AM
Peter C
Reply to hidesertman:
Pete[/quote]
Mike
[quote="hidesertman"] ........but a little tough to see the details of the fill and drain points in the scanned image...
Mike[/quote]
Mike, I took those pictures of a lube chart that I saw somewhere. I have what I think is an original operator's manual but the lube chart is not real readable. Some how I have a reasonably clear copy of a lube chart but no copy machine. Tonight I'll set my camera up on a tripod and take two or three (or more) overlapping pictures and then post them here.
Or, if you wish, I can go to the copy shop and have an 11" by 17" copy made and mail it to you. See if the photos work first, they're free.
Pete
Sat, Dec 2, 2017 6:36 AM
