L/pl 20 Steering Levers.
sammysourous
Send a private message to sammysourous
Need help, does anyone know how to remove the steering levers easily on a top seat 20 serial no L854.
Thanks for any ideas.
Wide 20
Wide 30
Tue, Feb 23, 2010 4:54 AM
bruce oz
Thank you received: 23
hello sammysourous,i don't know if there is a easy way ,you need to take the cover of oblong opening in front of the seat and undo each side adjusting nuts of each side lever ,not much room in there ,then the nuts around lever plate and then they should slide out as a whole unit .bruce oz
Tue, Feb 23, 2010 5:05 AM
sammysourous
Reply to bruce oz:
Thanks for that Bruce, i will give that a go.It will much easier to straightn them with them off the tractor as they got pretty bent during transport.
Wide 20
Wide 30
Tue, Feb 23, 2010 6:50 AM
| Kingaroy, Queensland
