LowBoy Q:?
LowBoy Q:?
Showing 1 to 10 of 19 results
§wishy
Send a private message to §wishy
OK my Off topic Q😕 is:
any body run an Expando Lowboy as in Murray or Cozad
mainly a left cost invention
Need to kno wot holds the RSend right in or fully expanded in width?
Thanx in advance
cya
§wishy
[CENTER]🙄 - : [B]ButEyeDoSt&2BCorrected : - 😛
Ifn U Get my Drift[/b]
😮 [/CENTER]
Sun, Apr 23, 2017 3:04 AM
7upuller
Hey Swishy,
Air cylinders open and close the expando suspension together or apart from 8.5' to 10' of travel. A purple weight chart in California from 4 tire group 8' wide is about 48,000 lbs on a tandem set of axles, where a 8 tire 10' will get you 60,000 lbs on a tandem group of axles.
Glen
Sun, Apr 23, 2017 7:52 AM
§wishy
Reply to 7upuller:
Hey Swishy,
Glen
Thanx Glen
Is the RSend pinned or does it rely on the full air cylinders to keep the expando RSend suspension in/out
thanx 4 th@
cya
§wishy
😮 [/CENTER]
Sun, Apr 23, 2017 8:10 AM
7upuller
Reply to §wishy:
Thanx Glen
thanx 4 th@
cya
§wishy
Swishy,
Air only. No pinning.
Sun, Apr 23, 2017 8:28 AM
§wishy
Reply to 7upuller:
Swishy,
Thanx Glen
Between terroizing the rds n the fone we have n a go @ making a Folding Gooseneck Expando
to get best benefit from the Govt weight wise
they say
rows of 8 can run MT @ 8'10" wide
@ 8'10" wide with a bogie spread @ 6' we get 24t
@11'5" " " " " " we get 31t
not to exceed 10' overall width in peek hour traffic (6am-9am .......... 4pm-6pm = 28t
So we need to be able to fix RSend width to @ least 3 positions
Thanx for the info Glen
[img]https://www.hcvc.com.au/forum/attachment/3389[/img]
Slo progress B n made :juggle: :juggle:
LOL
cya
😮 [/CENTER]
Sun, Apr 23, 2017 1:00 PM
mrsmackpaul
Reply to §wishy:
Thanx Glen
they say
LOL
cya
Swish Man I have been watching this build with great interest on the other truck forum
Are you gunna have it a swing wing type set up like a Drake up the front or some other idea ????
Is your gunna make it hydraulic IH had series of farm rams that had built in adjustable stops so us silly farmers could always drop the implement back in the same depth again and they worked very well were simple to adjust
A lot of the farm implements have real simple adjustable stops that lock things in place at easily set and adjustable spots
Paul
Sun, Apr 23, 2017 4:37 PM
§wishy
Reply to mrsmackpaul:
Paul
Mrs
Gudday m8
Thnx for u're interest
we got a swing wing drake .......... and it aint gunna work like a drake
the deck will stay @ 2.7m (8'10") but the RSend will widen out to 3.5m (11'5") max width without escort
to widen we got 2 air rams to shuv it in or out
heresa UToob of the yankee Murray trailer
[url="https://www.youtube.com/watch?v=cTLG6AW71yU"][img]https://i.ytimg.com/vi/cTLG6AW71yU/hqdefault.jpg?custom=true&w=336&h=188&stc=true&jpg444=true&jpgq=90&sp=68&sigh=P2p4QqS-FUsZ8QhXdg-ddA5uD7A[/img]
Clikity .............................................. ClikClikClik[/url]
Cya
§wishy
😮 [/CENTER]
Sun, Apr 23, 2017 5:08 PM
mrsmackpaul
Reply to §wishy:
Mrs
Gudday m8
Cya
§wishy
Swish Freighter Australia made a float like your talking about back in the 70's
I think it was quad axle and only the ass end got wider the deck stayed the same
I could find some info on it if it is of any interest for you
Paul
Sun, Apr 23, 2017 6:34 PM
§wishy
Paul
Mrs
Gudday M8
Back in th@ era most trailer makers had a go @ make n widners
normally a 2 hour job to widen/narro for 2 men n a few jacks etc
we stihl have our V: in the grave yard went 10' 11' 12' 13' with a narro tapered scraper neck
then they went n outlawd MT travel for wide trailers
[img]http://beamish.beamishheavyhaulage.com.au/pictures/s/s011.jpg[/img]
[img]http://beamish.beamishheavyhaulage.com.au/pictures/s/s026.jpg[/img]
[img]http://beamish.beamishheavyhaulage.com.au/pictures/d/d009.jpg[/img]
[img]http://beamish.beamishheavyhaulage.com.au/pictures/w/w064.jpg[/img]
cya
§wishy
😮 [/CENTER]
Mon, Apr 24, 2017 6:20 AM
Thank you received: 77
Reply to §wishy:
Mrs
Gudday M8
cya
§wishy
Swishy, can you remind me what the SAR rules are that had the cab sitting up like that? Are they still in play or superseded?
Mon, Apr 24, 2017 6:50 AM
§wishy
Gudday m8
many moons ago we had a very strict length law along the East Coast of Australia
Wen the 1st batch of KW 'S' models arrived from yanky land they had a BBC 90"
n with the need for speed or more power
KW Australia developed there own V: in 1975 (@ 102" BBC KW Short AustralianRighthanddrive)
the cab was mounted high so a more efficient radiator & cooling package could B offered n allow the heat build up escape out under the rear of cab
[img] http://www.hankstruckpictures.com/pix/trucks/robert_dick/brochures/kenworth_sar_1275_2.jpg[/img]
The KW SAR was very successful th@ lasted bout 11 years (1975- 1986)
so wen they stopped makin the SAR they went included the SAR name in a few later models
cya
§wishy
😮 [/CENTER]
Mon, Apr 24, 2017 10:53 AM
