My machine is a 977 20 A with the D318
I cracked the lines and number 3 cyl wasn't dropping.
Tested compression on 2 and 3, got 350 PSI, which I was told was low
Pulled off inspection plate and looked for a stuck plunger, didn't see anything, things seem to be moving up and down.
Also tried running threw ultrasonic then swapping out injector nozzles in 2 and 3.
The machine is a dog on power, hard to get a full scoop of dirt, won't hardly go up a hill in 2nd with a scoop of dirt, etc.
Do you think the injection pump is worth rebuilding or where should I go from here? The compression being low has me spooked. Wish it had more black smoke and fuel coming out of the engine under load. It does OK as a first gear small tree pusher but struggles with dirt work and I"m about to give up on it.
Other thing I was wondering will a clogged fuel filter cause the machine to be low on power? The fuel gauge shows pressure is good.
I have a video of the injector pumps going up and down, I'm about to give up, watch think, lost cause?
https://photos.app.goo.gl/pQnBdPmV7Cc6Nn6p6
Machine has a nice winch on it, loose tracks, leaks, but is a ton of fun other than being low on power. I'm really hung on it not having enough grunt to push the crap I wanna push.
