Looking to buy new grousers for D4-7U,need help
Showing 1 to 6 of 6 results
RobertShaver
Send a private message to RobertShaver
Thank you received: 8
I would like to put new grousers on my D4 7U
Does anyone know who I should call? I need 68 of them and I want them to be 20” wide.
The bolt holes are 9/16”
Any information would be great, I don’t have a part number either
Thanks Robert
Mon, Dec 7, 2020 5:44 AM
Thank you received: 54
i have a parts book and here are the part no.s for a 44inch guage tractor 13 inch heat treated shoe 3B2778 which transfers to 4K7052. bolts are 8H-1584 nuts 8H-5724 lock washer 3B-4508
find your self a parts book that cover your machines serial. it is very helpful to have. a owners book and serviceman's reference are another 2 book to get. try ebay for the books.
if the grousers are only worn down you can also rebuild them by welding on pieces of grouser building bar, medium grade steal flat bar or even deformed bar you must use low hydrogen 6018 0r 6016 welding alloys to do this and prevent cracking gp rods can crack easily and often wont hold on medium tensile steels. 6016 also known 16tc or twin coat are the easiest low hydrogen rods to use and most cost effective.
edb has posted data sheets on the reclamation process it was also in issue 152 of the acmoc magazine pages 40 to 44.
if you contact your local dealer they may be able to find you a listing and give a price for new grouser shoes make sure your seated as sticker shock may get you. just remember these are machines in preservation not working machines there days hard work is long finished and don't need to be perfect showroom condition unless you want to spend an absolute fortune and never get it dirty.
aftermarket parts are available for some machines too.
[attachment=61390]cattrackwearchartaf3.jpg[/attachment]
Mon, Dec 7, 2020 10:21 AM
Thank you received: 288
Reply to trainzkid88:
Robert: I’ve purchased new aftermarket pads for what I felt was cheaper than the effort of new grouser bar. $18.00 each for 18” but the holes might have been 1/2 or 5/8”.
Contact your favorite track shop.
Happy hunting. Gee
Mon, Dec 7, 2020 10:42 AM
I went to a steel fabricator and he had a bunch of 3/8 A588 plates that he cut out a whole set of 1 1/2' bars I welded them to my grousers with 6013 rods
[attachment=61397]ibm 254.JPG[/attachment]
Tue, Dec 8, 2020 2:38 AM
kittyman1
Reply to dpendzic:
nice fix...i prefer 6011/ 6010 welding rod for more penetration and burn thru the rust etc...crank it up
Tue, Dec 8, 2020 9:50 AM
Reply to dpendzic:
[quote="dpendzic" post=224206]I went to a steel fabricator and he had a bunch of 3/8 A588 plates that he cut out a whole set of 1 1/2' bars I welded them to my grousers with 6013 rods
[attachment=61397]ibm 254.JPG[/attachment][/quote]
6013 are general purpose rods not controlled hydrogen 6018/6016 are hydrogen controlled. the reason for using them is crack resistance and higher tensile strength in the finished weld.
hydrogen causes weld enbrittlement and cracking so does very cold or damp/wet steel.
Tue, Dec 8, 2020 2:51 PM
60K tensile strength is the same with any flux on a rod--i know a lot of specs call for 7018 rods. including the one i used for bridge steel design--but i have an old buzz box and the 6013 seem to work really well for me--those grousers bars are now over 10 years old, not a one has cracked and i use it in the New England mountains where there is mud or ledge rock and below zero temperatures--also i kept the ends a bit shorter than the original to reduce stress
Tue, Dec 8, 2020 8:57 PM
