Looking for specs on Cat 966B
Showing 1 to 9 of 9 results
Rd6 plower
Send a private message to Rd6 plower
Have specs for 966C wondering if there the same
And what are main differences between B and C?
Thu, Apr 28, 2016 1:57 AM
josh
Thank you received: 13
966A, 33A series, D333T, 140hp, 94" WB, 33A1454-up 122" WB, 2.5 yd. 1960-63
966B, 75A series, D333T 150hp, 3.0 yd. 1963-67
966C, 76J, 78G, 42J, 30K, 25U, series, D333T, 170hp, 4 speed, 4wd, transmission neutralize brake petal, plus many changes through the series 1967-1980.
966D, 99Y, 35S, 94X, 1981-87
966E, 35S, 1987-91
966F, 4YG, 1990-up
and more
Thu, Apr 28, 2016 3:15 AM
catsilver
Reply to josh:
966E, 35S, 1987-91
966F, 4YG, 1990-up
and more
There was little difference between the 966B and 966C, the B had the 4.5" bore engine and the C had the 4.75" bore D333C/3306.
Thu, Apr 28, 2016 3:32 AM
Thank you received: 46
Reply to catsilver:
966B (75A) 1963-68 uses the D333aT (4-1/2" bore)
966B (76J) 1968-80 uses the D333cT (4-3/4" bore) until 76J7946 then uses the 3306T with sleeve metering.
76J1063-up has flow amplified steering.
Both are articulated steering.
Thu, Apr 28, 2016 3:47 AM
ChuckC
Send a private message to ChuckC
I think the B model had a two speed ps trans next to the seat and forward reverse shifter on the steering columb(sp?). The C model had three speed ps and forward reverse all on the columb.
Chuck C
Thu, Apr 28, 2016 10:21 AM
Kelly
Reply to ChuckC:
Chuck C
[quote="ChuckC"]I think the B model had a two speed ps trans next to the seat and forward reverse shifter on the steering columb(sp?). The C model had three speed ps and forward reverse all on the columb.
Chuck C[/quote]
Here you go Chuck,
[attachment=35285]Cat 966B shifting_1.jpg[/attachment]
Kelly
Fri, Apr 29, 2016 3:55 AM
Thank you received: 32
Reply to Kelly:
Chuck C[/quote]
Here you go Chuck,
Kelly
I believe as well as the Trans gear lever change and other mods mentioned above, the C had a Hydraulic Oil Cooler fitted.
It was a mod I was going to mention to Cat of Australia Engineers when I came home from Nam as we used to often get the hydraulics boiling when working hard in the USA Engineers quarry loading over large ( for a 966) USA Engineers dump trucks with blast material out of the face or loading our Mark 5 International 5 yard tip/dump trucks with 3" minus from the crusher stock pile.
I was pleased to see that our first New Equipment stock C had a cooler fitted.
Often saw a blue tinge on the tilt rods and the rain, at times, would seem to sizzle on the cylinders and rods.
Fri, Apr 29, 2016 8:00 AM
Rd6 plower
Reply to edb:
The serial is 75a 3569. What year is this one?
Sat, Apr 30, 2016 1:54 AM
Reply to Rd6 plower:
1966 model
Sat, Apr 30, 2016 6:26 AM
L364
Send a private message to L364
1966 model
[attachment=35291]004.jpg[/attachment][attachment=35292]003.jpg[/attachment][attachment=35293]002.jpg[/attachment][attachment=35294]001.jpg[/attachment]
hi
i hope their here ?
Best regards
gary
Sat, Apr 30, 2016 12:56 PM
