Looking for specs on cat 18-28 pull rippers
Showing 1 to 7 of 7 results
Rd6 plower
Send a private message to Rd6 plower
Can anyone also tell me the year of serial 6D1137 I think it may be a 18?
Fri, Jun 17, 2016 11:44 PM
6Dxxxx is a #18, 7Dxxxx is a #28. I don't have the year builds.
Sat, Jun 18, 2016 2:08 AM
Rd6 plower
Thank you this is exactly what I was looking for
Sun, Jun 19, 2016 12:36 AM
D6 Pete
Reply to Rd6 plower:
Did the 28s only have the heavy push type of pull lug on the back ,, or some 18s as well!!??. I have a 28 here with the big lug on back to carry the D8s blade I guess ,, also by the marks on it from pushing!!!! .. pete
Sun, Jun 19, 2016 9:03 AM
D6 Pete
Reply to D6 Pete:
#28 and Cat 8R D8[attachment=36487]DSC00594.jpg[/attachment]
Sun, Jun 19, 2016 9:23 AM
hotrodwelder1
Send a private message to hotrodwelder1
Reply to D6 Pete:
wish i had a ripper for my D6 2H to make it sweat a little..........
Mon, Jun 20, 2016 9:29 AM
smokenrust
Send a private message to smokenrust
Reply to hotrodwelder1:
Hello fellows, I know this thread is couple years old already, but thought it would be a fine place to ask my question. I seen a Cat ripper and looked at it for a minute but then had to get on with other more pressing things.. Got home and see it looks like an #18 or #28 ripper, but they look almost identical... So, how can you tell which is which from a distance? They both look heavy and long.
Next question would be , what is a ripper like this worth? This ripper has only one tooth left and the right holder for the pin to go through the tooth attachment has been torched off and looks like it got used pretty hard and has some welding done on it and rusty and lichen growing all over it with leaves covering it. Steel wheels and has a bump in the back, but not a hitch as sticking out as in picture above shows. There is what appears to be an angled slot on top for pinning something at an angle. Did not get close to see if it went all the way through. Took a quick look to see if I could find the ID plate, but didn't see it. so where is that located at? TIA
Wed, Oct 10, 2018 3:35 PM
Reply to smokenrust:
Look for the s/n plate on the top of the main body within the wheel frame.
A little tough to spot the differences from a distance.
The #18 has 3 x 9 shanks, the #28 has 3 x 10.
Wheel gauge on the #18 is 58", the #28 is 62"
#18 is 9,125 lbs, the #28 is 13,100.
I believe just the #28 has the big lug on the rear.
Wed, Oct 10, 2018 10:46 PM
