Looking for some spares: D7E 48A-series
Showing 1 to 10 of 11 results
dewets
Send a private message to dewets
Hi guys,
We're looking for a set of contacts (points) & condenser for the starting engine on a D7E 48-series.
Bear in mind that we're located in South Africa.
Local CAT agents non-compriendo regarding availability
Somerset West, Cape Town
South Africa
Sun, Jul 1, 2007 10:07 PM
dewets
Hi all,
Could somebody please forward me the part #'s for a set of points and condenser for the starting engine on a D7E 48A series.
South Africa
Thu, Jul 5, 2007 2:07 AM
English Al
Send a private message to English Al
Reply to dewets:
Hi all,
THYS. been looking at the 48A microfisc and they don't list separate parts only magneto overhaul kits unfortuatley these are all dicontinued (no longer available) but it does say in the NPR refer to service magazine dated
07 August 1989. Sorry but I do not have these maybe your cat dealer has them!! Not much help i'me afraid but I did try. Al 😕
Thu, Jul 5, 2007 3:32 AM
Reply to dewets:
Hi all,
Not all that easy😉
From the 48A1- up parts book the mag is a Cat #7M4700
The condenser is a Cat #2M2757
The points are only offered in the Cat #7M7859 overhaul kit (which includes condenser).
This is a Wico magneto and to get to the individual parts the Cat to Wico equivalent conversion number is required (I don't have) then approach source for Wico magneto parts.
This might get you closer:
From the 47A3396-up parts book:
The mag shown is a Cat #3S2987 which crosses to a Wico # XH2823S
Uses the same #7M7859 overhaul kit.
Hope this helps
bcwayne
Not all that easy😉
Hope this helps
You might try checking with www.standardmagneto.com they are located in Chicago,USA...... if anyone has those parts,they would. Good Luck
Thu, Jul 5, 2007 4:18 AM
josh
Thank you received: 14
Reply to bcwayne:
For 48a1-up,
Magneto assembly, 7m4700,
Contact kit is 7m7860, wico # is:k12770
Over haul kit is7m7859, wico# k12771
Condenser is 2m2757, wico # x6916
Thu, Jul 5, 2007 9:44 AM
Reply to josh:
For 48a1-up,
All right josh😄 😄 I take it you are in possession of some Wico info. I'll refer to you next time😊
Thu, Jul 5, 2007 10:09 AM
Hi Josh,
On further checking a little help required😊
The "contact" kit 7M760 list includes cam wiper felt, contact group and screw assembly.
The "overhaul" kit list includes gasket, oil seal, bearing, oil slinger, carbon & and spring group, ground connection group, breaker contact group, condenser group and screw assembly.
Is the "contact group & screw assembly" the same as the "breaker contact group"?????
Maybe the Wico version would clarify. Thanks
Thu, Jul 5, 2007 11:00 AM
josh
Hi Josh,
Hi OM,
Sorry to say but my information does not have a break down of what is in the "kits"
My numerical parts record has a cross reference section of part numbers from Caterpillar suppliers to Cat and visa-versa,
I seem to be able to cross most of the suppliers part numbers on our "classic" tractors,
Josh
Thu, Jul 5, 2007 9:59 PM
mgood
Send a private message to mgood
Reply to josh:
Hi OM,
Josh
dewets; sorry i can't help You on Your needed info;bcwayne thank's for posting that address. I believe they are going to help with one of my mags thanks for the info. Dewets i hope someone can help You with the info that You need. mlg
Fri, Jul 6, 2007 4:32 AM
dave morgan
Send a private message to dave morgan
Reply to mgood:
Chicago Magneto also has the parts you need. It is a Wico mag.
Sat, Jul 7, 2007 12:50 PM
