Looking for some help
Showing 1 to 7 of 7 results
62Edanny
Send a private message to 62Edanny
I'm taking a shot in the dark here I hope someone will read this and be able to help.......
Next year will be my fathers 50th anniversary of his tour in Vietnam. He was a combat engineer. I would like to build a model of a road scraper that he did a lot of work with over there and give it to him a as a gift. I have a few pictures of his that I can use for reference.....but I am having a very hard time finding the model kit. I want to build it in 1/35 scale but at this point I will use anything I can find. From research I have done I believe what I'm looking for is a Caterpillar 830MB or maybe a 290M WHEEL DOZER & SCRAPER . I was hoping you may have some information on possible model kits or even a diecast one. I am a skilled model builder and I would be able to convert a diecast civilian scraper to look like a military version. Any help you may have would be a huge help. Thank you very much
Danny
[email protected][attachment=28341]image.jpg[/attachment]
Sun, Apr 5, 2015 8:48 PM
Quadrajet2000
Send a private message to Quadrajet2000
if you want to build a Cat version you can start with a Cat 834 wheel dozer model by spec cast I think that's who made it; just look on eBay for one. The early 834s were basically the same machine in real life just backwards hence the platform would need to be reversed , the blade needs inside mount push beams, cab added etc but it's a darn close start. The scraper bowl was usually either a Westinghouse/Curtiss Wright or Euclid so if you can find a correct scale scraper model just use the bowl off of one. I can share some photos of my actual machine if you need help just ask.
Anyway best of luck.
Thu, Dec 10, 2015 10:28 AM
ronm
Reply to Quadrajet2000:
You want a real one? I think I know where there was one of those sitting, with a seized engine, as of a few years ago...may be gone, I haven't been by it lately.
Thu, Dec 10, 2015 9:25 PM
old-iron-habit
Reply to ronm:
There are two municipal units, both 290M tractors only, set up as push cats up for sale on auctiontime.com closing next week on Wednesday late morning. I believe they are near the same as the 830.
Fri, Dec 11, 2015 2:21 AM
oldtanker
Send a private message to oldtanker
Reply to old-iron-habit:
IIRC the 830's replaced the 290's and are very similar. I don't have much time on them but I've operated both.
Rick
Fri, Dec 11, 2015 2:35 AM
Thank you received: 105
Reply to oldtanker:
Rick
Hi, Oldtanker.
The 830MB was the Cat machine and the 290M was a Michigan more or less equivalent. Check this link:
https://www.google.com.au/?gws_rd=cr&ei=DdlpVvqqCcO00gS374rABQ#q=clark+michigan+290m
Fri, Dec 11, 2015 2:54 AM
oldtanker
Hi, Oldtanker.
[quote="Deas Plant."]Hi, Oldtanker.
Just my 0.02.[/quote]
I knew the 830 was Cat but didn't know who made the 290. I believe the 290 was replaced by the 830. I know both were in service in the early 80's.
On a side note the Army bought a grader sometime in the 70's. Parts for it were a nightmare. I was told by an Engineer motor Sgt that the company that built them went out of business right after they delivered the last one. By the time I retired they had replaced it. Can't remember if they went JD or Cat. Back in those days (early 80s) the engineers had both a 2 1/2 and 5 yard loader. The 2 1/2s were Case and the 5 yard was a Michigan.
Rick
Fri, Dec 11, 2015 3:24 AM
Thank you received: 60
Reply to oldtanker:
Rick
There's an 830 and scraper pair on that website. The photos might be useful to you
Fri, Dec 11, 2015 6:25 AM
