Looking for info on 3T-D7
Showing 1 to 9 of 9 results
bosco
Send a private message to bosco
Could anyone give me the basic info on a D7, s/n 3T26302
Such as year built, weight, etc?
Gonna buy one from a friend of mine and am curious.
I will try to post some pics
Wed, Sep 22, 2010 8:34 AM
Claney
Send a private message to Claney
The D7 you are looking at is a 1954 year model. Think the weight is around 26,000# , but not for sure.
Good luck
C u.............Claney
Wed, Sep 22, 2010 9:30 AM
Thank you received: 46
Reply to Claney:
Good luck
Here's some specs....kinda rare to get the hydraulic blade set up.
Has direct start conversion.
Wed, Sep 22, 2010 9:56 AM
Jack
Reply to Claney:
Good luck
Looks like it's been converted to direct electric starting. If it's hot where you'll be running it, I suppose it will start OK, unless the engine is pretty lame.
bosco
Reply to Jack:
Thanks for the info...
It has been converted to electric start. They went to clear a fence row a few years ago and got rained out. When they went back after some time it wouldn't
start. Think it got water in the head. The owner wants it gone, so I will buy it for
scrap price and see if we can get it going.
My family has been in the dozer business for 70 years and I want it for a toy and to save from the scrap-man.
My current tractor is a 6T with enclosed cab and diff steer and I learned on 7E, so this will be a new experience for me!
Wed, Sep 22, 2010 10:33 AM
Reply to bosco:
Does look like it has been "resting" for a long time.
Wed, Sep 22, 2010 11:12 AM
chriscokid
here is the Nebraska Test for the D7, the 7M was the one tested
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1977&context=tractormuseumlit
Wed, Sep 22, 2010 5:50 PM
Old 3T lover
Reply to chriscokid:
35 years ago, I had a 3T just like that one. If I remember correctly the serial # was 3T 23717. They were dang good old tractors.
I see the one you are buying has some updates like the one I had. Bolt on sprocket rings, lifetime top rollers on the raised stands. Mine also had the grease type track adjusters.
Since you have dozers, take the fuel injectors out, put in a little fuel on the pistons and let her sit a few days. Then push her around until you break the engine loose, re-install injectors and try to fire her up.
You may have to put in some new pistons and sleeves but that can be done through the side plates, no problem.....well....except for the #1 hole. The hydraulic mounts make it a little tight about getting to #1.
Wed, Sep 22, 2010 6:58 PM
Jack
Reply to Old 3T lover:
I did an in-frame top end on my D7 3T, will share this gem of wisdom.
Pull the covers off the bottom of the water jacket and flush, poke, brush, pressure wash, or anything else you can think of to do, preferably after the heads are off, before you pull sleeves. Then tape the crankshaft throws, especially the oil ports.
I didn't, and you can't imagine the crud I had to mop out of the crankcase after the sleeves came out!
Sat, Sep 25, 2010 9:38 AM
Wascator
Send a private message to Wascator
Reply to Jack:
Hi, I just found this. My Dad had one of these in north Louisiana back in the late 1970s; think he sold to someone in Arkansas. He let it rain in the exhaust once and one of the exhaust valves rusted until it would not seal. A neighbor who was a Diesel mechanic fixed it. It sure ran great and had tons of torque.
Just wondering how you came out with it in the past few years...
Thu, Nov 9, 2017 3:17 AM
