Little oil leak D-6 9U
fred hogan
Send a private message to fred hogan
my D-6 has been sitting for about two weeks and noticed some lubricant on track below left sprocket. What's it going to take and fix this?
Tue, Nov 1, 2016 10:19 AM
fred hogan
Here is a picture of the oil leak.
Tue, Nov 1, 2016 10:25 AM
old-iron-habit
Reply to fred hogan:
It is coming out of the final drive seal on that side. may have a loose or bad bearing. Not sure about the repair procedure but I believe you need to pull the sproket. That takes a good puller and needs to be pressed back on. Meanwhile make sure you fill it when you use it via the pipe plugs right inside the track on the back.
Tue, Nov 1, 2016 10:50 AM
Headerpuncher
Send a private message to Headerpuncher
Reply to old-iron-habit:
Worked on a road job back in the 50's and we had a D-6 pulling a roller. One final drive started leaking pretty bad. Boss didn't want to shut it down as we only had about a month to finish before winter. Older Irish fellow was the oiler. He told the boss, I think I can stop that enough to finish. Boss said go ahead. He went to town and bought a couple boxes of cornstarch and worked it in as he was filling the final drive. Took about an hour and it quit leaking, seeped some but we finished the job and they fixed it right that winter. Worn bearing that let the seal get out of line.
Sometimes they just do that and I you run them a while they will quit if your lucky.
Tue, Nov 1, 2016 2:16 PM
Reply to Headerpuncher:
I think the procedure is to take a bar and see if there is any horizontal play in the sprocket---if there is, the preload on the sprocket bearing may need to be adjusted.
Tue, Nov 1, 2016 7:58 PM
Yes, run that track up on a board or something so the sprocket is clearly not bearing weight and then pry between sprocket and track frame to check for movement. Any movement means you have a loose or failing bearing or the sprocket is loose on the hub. One out of 3 can be a good thing.
If the oil is clearly on the outside of the sprocket and not on the inside and there is no slack, you can change the outer seal without pulling the sprocket. To replace the inner one, the sprocket must be pulled.
Wed, Nov 2, 2016 1:04 AM
