lifting cap of a 922B
chriscokid
I have found a 922B wheel loader but wondered what the lifting cap is?
the info i have found so far stated 12000# at a low lift and 7000# at max height, would this be right?
Thanks for your help
Wed, Dec 10, 2014 8:02 AM
KCB
Send a private message to KCB
Erik: The specification format changed over the years. For the 922A the lift capacity was 16,500 lb at ground level and 8,500 lb at max height. This is a hydraulic capacity, the machine will tip (raise rear wheels) at less than 16,500 lb load. The exact tipping load depends on engine and counterweight options. The 922B has increase wheelbase, 78" --> 86", and thus greater actual lift capacity. For the B the tipping load is listed as 10,500 lbs., but again depends on engine and counterweight options.
Wed, Dec 10, 2014 9:09 AM
chriscokid
Reply to KCB:
Thanks Kent
Wed, Dec 10, 2014 7:09 PM
