leaking heads?
leaking heads?
whiteiron
Send a private message to whiteiron
Thought i'd share this stuff with the board,http://www.usasealants.com/products/blue-devil-head-gasket-sealant/ finally put water in my d69u this week and came out in the morning to find a puddle on the floor. Needless to say I was very disappointed,a friend told me about a product he used on his western star with a cat engine that he swears by and they even guarantee your money back. Bought it at my local napa store; very expensive though @ 60.00 a bottle and it took 2 to do the job.Had to flush the engine out and filled with clean water, took the regulators out and ran the engine for an hour with the pony running (to get full circulation). drained 5 gallons out , reinstalled regulators and added antifreez. It worked, been sitting for two days now and the floor is dry. I'm sold on the product and it saved alot of work!👍
Mon, Jan 10, 2011 12:04 AM
u-joint
Send a private message to u-joint
possible that your head needed a good old retorque.
thats an interesting concept! rather than a retorque, fill the cooling system
with bars leak.
Tue, Jan 11, 2011 2:12 PM
whiteiron
Reply to u-joint:
with bars leak.
Did that, shaved the head and not the block, possibly a little off. This product is far superior than bars leaks. Its a liquid form of sealer, which searches out imperfections in the mating surfaces, read about it.
Wed, Jan 12, 2011 5:24 AM
Thank you received: 60
Reply to whiteiron:
That appears to be the old "water glass" (sodium silicate). Been around for ever and is a good waterside sealant. Most famous recent use was to kill engines turned in on the "klunker" program by pouring it in the oil and running until unit froze up.
Wed, Jan 12, 2011 1:25 PM
