late model d2 radaitor
Highwide20
Send a private message to Highwide20
I'm looking for the part number of the radaitor core for a late model d2 with a 4 bladed fan. Serial number 18,6xx. Does anyone make these afermarket? Thanks mike
Thu, Aug 9, 2007 9:12 AM
Thank you received: 39
Part number is 6H9853 core assembly.
Don't know source but I'm sure they are out there.
Better be sitting down when you get the price.
Also check to see if it has the two different thickness tube sheets.
The last one I saw new for a D4 was well built but both tube sheets were the same thickness. Just enough to throw off upper line and brace connection alignment.
Thu, Aug 9, 2007 9:27 AM
84WD10
Send a private message to 84WD10
Hello miked238,
I note that you are searching for the radiator core Part No forthe late model "D2", effective with Serial No 5U 17569 up.
Radiator Core part No 6H 9853. Taken from Parts Book - Form No 32373, published July 1957.
Hope this hopes.
Regards
Alan. T. Lewis
Christchurch
NEW ZEALAND
Thu, Aug 9, 2007 9:36 AM
B4D2
Reply to 84WD10:
Hello miked238,
Hope this hopes.
Regards
Alan. T. Lewis
Christchurch
NEW ZEALAND
Mike, where in Illinois are you? I have a late model parts machine that may have a good core for you. I am in Chicago, and the parts machine is in NW Indiana.
Thu, Aug 9, 2007 9:07 PM
Highwide20
Reply to B4D2:
Is there a number you can be reached at? mike
Thu, Aug 9, 2007 10:09 PM
B4D2
Reply to Highwide20:
Mike, I sent you a Private message
Fri, Aug 10, 2007 12:16 AM
