late D4 horsepower
late D4 horsepower
Showing 1 to 10 of 12 results
bursitis
did the D4 7U increase in horsepower as the series matured?  lets say a 1957 model five roller D4 compared to a 7U of earlier years?  did the transmission group stay the same all the way through?
Sun, Feb 6, 2022 8:27 PM
willwingo
Thank you received: 5
----deleted----
Sun, Feb 6, 2022 9:27 PM
Reply to willwingo:
----deleted----
Answer can be found in the rack setting charts (bible)
  [attachment=66693]D4 Rack Setting #1.jpg[/attachment]
Sun, Feb 6, 2022 10:52 PM
D4Jim
Thank you received: 12
Speaking of the D315 engines, I can notice a lot of difference in the horsepower and sound of my 112 3U (1949) and my D4-7U (1950) particularly the RPM's. 112 much higher pitch.
Thanks OM.
Cats Forever
Mon, Feb 7, 2022 2:42 AM
Fat Dan
Reply to D4Jim:
Thanks OM.
Old Magnet, footnote # 12, I assume* must be the break between 955C and 955E at 12A5793? that's good to know the rack setting are different. Thank you.
*yes I know...
Mon, Feb 7, 2022 3:17 AM
Reply to Fat Dan:
*yes I know...
The other footnotes...
  [attachment=66694]D4 Rack Setting #2.jpg[/attachment]
Mon, Feb 7, 2022 4:15 AM
bursitis
they added quite a bit of horsepower from the early 6U--7U series to the later. please explain the 5H607 gear group?
Mon, Feb 7, 2022 8:05 AM
willwingo
Reply to bursitis:
----deleted----
Mon, Feb 7, 2022 8:59 AM
bursitis
Reply to willwingo:
----deleted----
1st-1.34 2nd-1.85 3rd-2.72 ?? is 5th 5.37? is there no 4th? i guess there is another lever that makes reverse Hi/Lo?
Mon, Feb 7, 2022 9:09 AM
Thank you received: 21
Reply to bursitis:
Phildirt put the shift pattern just above where he wrote "I mostly see...." There's only one shifter, and instead of a fifth gear, it has LR and HR
Wed, Feb 9, 2022 5:55 AM
bursitis
Thanks much. i guess this arrangement was for bulldozer application instead of as an agriculture tractor?
Wed, Feb 9, 2022 6:14 AM
