Late D2 Down Exhaust pipe
3J1Bill
I would like to put a down exhaust pipe on a late model D2 like it had when new. It is a low seat direct start tractor for orchard work. . If someone has a  "Blue Print" you could post, it would be a real help. It looks simple, but I want to get it right. Bill
Thu, Sep 2, 2021 10:30 PM
Thank you received: 54
looks like there is a elbow not shown or the manifold is different.
it was a common conversion on ferguesson tractors they simply had a different elbow that bolted on and the exhuast pipe was made to suit it even used the same muffler.
Fri, Sep 3, 2021 2:59 PM
rax200
Reply to trainzkid88:
Hi trainkid88,
What you did to have a down exhaust is turn the manifold upside down then use the down exhaust pipe.
Regards
Fri, Sep 3, 2021 3:27 PM
Reply to rax200:
Hi trainkid88,
Regards
that explains it. and its a elegant solution so simple.
Fri, Sep 3, 2021 4:01 PM
