latch screws on D2 starter pinion
D2MOVA
Send a private message to D2MOVA
Hi guys
Hoping for some help here i have pulled the starter pinion to pieces and forgot to count the number of turns to have the screw flush and then how many to turns to get in the right position for starting
Mon, Jan 14, 2019 6:02 AM
d2gary
If you search on the BB there is reference to your question.
If I remember correctly others have told me 1 1/2 turns will get you close. I replaced the latch spring on mine and that adjustment was really close.
Should add that was with the screws flush with the housing then count your turns
Mon, Jan 14, 2019 6:32 AM
Thank you received: 92
from observation over the years a good starting point would be around 1/2 a turn of the screw head in below flush of the latch end and start from there.
Scan below may help with the adjustment.
Mon, Jan 14, 2019 6:45 AM
ag-mike
Reply to edb:
i believe toby says just about flush to start out when putting it back together in his video.
Mon, Jan 14, 2019 7:26 AM
Sasquatch
Thank you received: 5
Reply to ag-mike:
Yep that's right, that setting is a bit on the light side and usually needs another 1/2 to 1-1/2 turns in to end up where it needs to be (every machine is different) but I like to sneak up on it knowing that the first start isn't going to ventilate the pony motor because the latches were too tight.
Mon, Jan 14, 2019 10:32 AM
