Last Direct Drive Cat
R W
Send a private message to R W
Anyone know when the last direct drive Caterpillar was available.
Mon, Nov 3, 2008 3:11 PM
bruce oz
Thank you received: 23
hello r w ,the book i have show a d8L 4fb 400 hp special application tractor ,built 1984 to 1987 ,built for farming ,bruce oz
Mon, Nov 3, 2008 5:07 PM
FatCatGotHot
Send a private message to FatCatGotHot
Reply to bruce oz:
Clickn here will get you to some photos of D8L SA tractors: http://www.farmphoto.com/FPv2/thread.aspx?mid=628260
Mon, Nov 3, 2008 6:44 PM
bruce oz
Reply to FatCatGotHot:
hello found 2 more that had dd up till 1997 ,bruce oz
d4h 4nk up till 96
d5h 4kd till 97
Mon, Nov 3, 2008 7:02 PM
gwhdiesel75
Reply to bruce oz:
d4h 4nk up till 96
d5h 4kd till 97
For those of us who aren't sure what "direct drive" is, please explain.
Mon, Nov 3, 2008 8:10 PM
cr
Send a private message to cr
Thank you received: 25
Reply to gwhdiesel75:
Cat also made a D7N SA as seen in my photo.
My relatives had some but sold them in the late 90's and early Y2K to replace them with 95e's which are now junk.
The tractor seen in my photo was used to pull a custom murray V ripper.
I believe they went overseas to Australia.
Mon, Nov 3, 2008 9:46 PM
d4c24a
not power shift just old fashioned clutch 😄
cheers graham
Mon, Nov 3, 2008 11:37 PM
gwhdiesel75
Reply to d4c24a:
cheers graham
Thanks Graham! GWH
Tue, Nov 4, 2008 12:00 AM
dtallon
Send a private message to dtallon
Thanks Graham! GWH
Cat made a D6R LGP Direct Drive and a D5M LGP DD in Japan until 2002. There was also a D6G "Super Rural" made in Brazil until 2001. In the US though, Cat chose to push the Challengers over the DD steel track tractors.
The D6R and D5M had powershift transmissions, but no torque converter. The lack of a converter is the main thing that makes a tractor direct drive; i.e. the engine directly drives the powertrain, with no converter fluid coupling in between.
Dave
Thu, Nov 6, 2008 1:34 AM
| Kingaroy, Queensland
