Laser rust removal.
Laser rust removal.
Showing 1 to 6 of 6 results
josh
Thank you received: 13
I want it! I need it! I will have to wait till they come down in price a bit.
https://www.youtube.com/watch?v=CLaBFkeHG0A
http://www.cleanlaser.de/wEnglish/produkte/high-power-cl-1000.php
Mon, Mar 14, 2016 12:52 AM
Hillbillybjopkr
Send a private message to Hillbillybjopkr
just one step closer to real laser blasters.....
Mon, Mar 14, 2016 1:02 AM
Thank you received: 57
Reply to Hillbillybjopkr:
I need to tell my sandblaster guy - no more cleaning sand out of junk
Mon, Mar 14, 2016 2:32 AM
vibrafinishlimited
Send a private message to vibrafinishlimited
Excellent rust removal service! Restores metal surfaces efficiently and leaves them looking brand new. To know more detals, read this :https://vibra.com/service/rust-removal/
Wed, Oct 15, 2025 1:46 PM
GrantJ
Thank you received: 7
Dry Ice blasting is the best system that I have seen. You dont get any grit at all, only whatever comes off of the material. It wont do deep rust, but what I watched at my old job was wonderful. The problem is that it is an industrial process that does not downsize to small shops or home shops. There may be large shops that do ice blasting, but I have not been able to locate one. Soda Blasting is another process with less grit issues, but sure is messy.
Wed, Oct 15, 2025 2:37 PM
wimmera farmer
They certainly work there is one near me . Not a commercial operation. Taking a bit of learning and dangerous . Eye protection is very important. Lens has to be perfcty clean. They have set up an extra compressor to try and keep debris away from the lens.
Wed, Oct 15, 2025 6:56 PM
Thank you received: 49
you can get portable dry ice blasters but its expensive equipment.
a method that works well for rust removal is electrolysis but it is a slow process.
soda blasting works well too.
Thu, Oct 16, 2025 3:24 AM
