Lang lay vs regular lay cable
1972RedNeck
Send a private message to 1972RedNeck
Putting the blade back on my D9D with a #29 rear CCU. The book calls for lang lay cable but I'm not having much luck finding any. What will happen if I use regular lay cable?
Mon, Sep 26, 2022 7:58 AM
Thank you received: 52
i would go to a joint that specialises in rigging for cranes and winches. they should be able to help you. the difference is how the cable is wound when its made. and how flexible it is.
does the book specify a diameter and strand count. example is 5/8 dia 10 x 25 strands
Mon, Sep 26, 2022 4:07 PM
PhilC
Not much will happen except maybe it won't last as long. Lang lay cable is more flexible which suits CCU's due to the number of sheaves they go around. The main thing is to get the correct number of wires and strands. I usually use whatever is available at the time and the difference in life of the cable is significant.
Mon, Sep 26, 2022 4:12 PM
Reply to PhilC:
Should use 1/2" 6x25 wire core, right lang lay.
Tue, Sep 27, 2022 12:05 AM
1972RedNeck
Book says 1/2" 6x19 independent core improved plow steel. Would 6x25 be better?
Tue, Sep 27, 2022 12:11 AM
Thank you received: 110
Reply to 1972RedNeck:
Hi, 1972RedNeck.
I don't know where you hail from but this company may be able to help - if you are not living on Jupiter - or somewhere equally remote.
http://www.fresnowirerope.com/
Tue, Sep 27, 2022 12:22 AM
From the #127 [Formerly #29} Operation and Maintenace manual.
[url=https://www.mazzellacompanies.com/learning-center/lang-lay-vs-regular-lay-ropes/]Lang Lay Wire Rope vs. Regular Lay Wire Rope Construction » Mazzella Companies
Tue, Sep 27, 2022 12:45 AM
1972RedNeck
Interesting. Must have been an update from my #29 book.
Tue, Sep 27, 2022 12:51 AM
thanks rome. confirmed what i thought. most crane cables ive seen are lang lay cables. and yes in operation a regular lay cable would be more like a steel bar when under load were as lang type cables would have more flex as the strands are more towards a 45 deg to centreline than the shallow angle of standard cable.
Tue, Sep 27, 2022 6:39 AM
