Issues with 'Private Message'
Showing 1 to 9 of 9 results
Crawler Dollars
Just wondering if anyone else is having issues? I've sent several PM's, never received a response, checked my 'sent' file and they are there. I checked with the recipients and was told that they did receive them and responded. Very strange. :confused2:
Mon, Apr 30, 2018 9:49 PM
d4angelo
Thank you received: 8
Try it when you are sober...............
Ha. Ha.
Mon, Apr 30, 2018 10:40 PM
d2gary
Reply to d4angelo:
Ha. Ha.
I had similar problems a couple of weeks ago
Tue, May 1, 2018 10:57 AM
Andrew
Reply to d2gary:
Yeah we often have Friday afternoon drinks.
Tue, May 1, 2018 12:15 PM
d2gary
Reply to Andrew:
That's funny, I was actually referring to the pm but I have a Friday afternoon drink also. Guess I have both problems then
Tue, May 1, 2018 11:20 PM
Thank you received: 289
C$$$: Did anyone from from Acmoc administration contact you in regards to your issue?
Sun, May 6, 2018 8:30 AM
Crawler Dollars
Negative JM...crickets, nothing but crickets. 😖leep:
Sun, May 6, 2018 10:51 PM
old-iron-habit
Reply to Crawler Dollars:
Did you go to the Forum's page and send your problem in under the Forum titled Bulletin Board Operations? That directs your question to the guru's that trouble shoot such stuff. I don't think they probably spend much time combing thru the "Discussion's" posts like some of us junkies.
Mon, May 7, 2018 6:07 AM
Crawler Dollars
Reply to old-iron-habit:
No I didn't. I first wanted to see if it was a wide spread issue or just something on my end. Seems to be working fine now, :whoo: so it seems to be a short term issue...hopefully.
Mon, May 7, 2018 8:57 PM
B4D2
Another consideration, perhaps the recipient has a full "in" box and cannot receive PMs. Users of the bulletin board should regularly clean out old messages as there is limited space. If there is important correspondence stored therein, you can download the messages into a text document and store it in your documents file and view offline.
Tue, May 8, 2018 8:47 PM
