Is This A DH8?
Is This A DH8?
bulletpruf
Send a private message to bulletpruf
It's a few hours away from me. Ad has lousy pictures and no details. Seller doesn't know much about it, either.
About all is know is that it has a cable blade, electric start, and "ran when parked."
My guess is D8H. Am I correct?
Thanks,
Scott
Mon, Aug 31, 2026 1:32 AM
bluox
No earlier 8
Bob
Mon, Aug 31, 2026 2:50 AM
Thank you received: 140
Hi, bulletpruf.
I'm gonna stick my neck out in the 'waiting-for-the-axe' position here and say either 1950 or later 2U, post hard nose and two lever transmission, or a 13A D8. Looks to be mostly there but a bit ovva project.
Mon, Aug 31, 2026 3:48 AM
Thank you received: 78
Typical clues are the H does not have that "T-shaped" dash that the 2U/13A has, but it does have an 8 bolt (or 10?) cover over the end of the dead axle, along with a turbocharger if you can see under the hood
Mon, Aug 31, 2026 5:58 PM
brian18a
Thank you received: 70
Early 36a D8H air
cleaners not original
Mon, Aug 31, 2026 7:26 PM
bulletpruf
Mon, Aug 31, 2026 8:09 PM
