Is it possible to do a final rebuild on d7e with out the press/ puller
Cdcompton
Send a private message to Cdcompton
My finals have wept since i got the machine. I was down in a pond bottom pushing muck and now have mud in my finals i dont have money to take to a mechanic or buy the expensive puller can it be done or am i toast??? Please help
Tue, Oct 22, 2019 8:38 AM
Thank you received: 140
Hi, Cdcompton.
You're looking at some pretty heavy pressures to get them off and put them back on. You might like to try hiring the gear to do it. Or see if somebody close to you can help out. I see you have your greater area location posted. Putting up your local town might give somebody who could help a better idea of how far away you are.
Tue, Oct 22, 2019 9:57 AM
Wombat
Donor
Hi, Cdcompton.
Providing you can get the outer hub off, it is possible to remove sprocket with housing an d bullgear and take to a press, is a very cumbersome way of repairing a final drive and you will need good lifting gear as you will have the weight of the final drive. It is much easier to get a press to the tractor.
Wombat
Tue, Oct 22, 2019 2:29 PM
Cdcompton
Reply to Wombat:
Wombat
I f someone close has one i could rent/borrow would be great i seen a guy remove a 955 sprocket with porta power and homade plate adapter but still dont know how i can get it back togather
Tue, Oct 22, 2019 7:26 PM
seiscat
Reply to Cdcompton:
Hi Cdcompton, if your serial number is 47A1- 47A3395(direct drive) or 48A1-48A6392(powershift) it is a low horsepower(160 hp) and the inner sprockets hubs are no longer available from any source new and super rare if not impossible to find used.
While I believe it is possible to remove the finals without a press, it is very heavy & difficult. The assembly will then have to be hauled to a shop to be pressed for rebuild.
Craig
Tue, Oct 22, 2019 8:28 PM
Reply to seiscat:
Craig
MacAllister Cat should be able to help you.
Wed, Oct 23, 2019 1:39 AM
