Is An Off Color Question Grounds For Impeachment?
Showing 1 to 10 of 21 results
Art From De Leon
Send a private message to Art From De Leon
I bought an A-C HD-21 brochure off of eBay, and on the air cleaner, the clean air pipe, runs from the body of the air cleaner forward, then turns down to a 'box' on the lower RH front corner of the engine, which seems a strange place for the intake manifold.
Was this engine supercharged, if so, the specifications make no mention of it, other than it being a 4 cycle Allis Chalmers Diesel.
Also, it appears that the thermostat housing is on the front of the exhaust manifold, was the exhaust manifold water cooled?
[attachment=34554]P1000557_1456.JPG[/attachment]
[attachment=34553]P1000556_1455.JPG[/attachment]
Thanks In Advance
Sat, Mar 26, 2016 2:50 AM
ronm
The HD-21 my cousin had was a turbocharged 844, but it may have been a later one than your pic...the early ones may have been different. That was a pretty good old dozer, it had a cable blade & a diesel torque converter. The 844 was a nice-running engine, smooth & started really easy. I did an in-frame on it, or I put it back together after he & his brother tore it down. By the time they got parts & the heads done it was December & -10 when I assembled the engine...right out in the open, in about a foot of snow...he had a space heater blowing under the tractor from the back, & an old salamander in front. Good times! NOT...I wouldn't do that for any kind of money now. 😄
The Allis-Chalmers forum guys probably know all about the differences. I know the HD-20 had a 6-110 Detroit, those were a beast...
Sat, Mar 26, 2016 6:19 AM
ronm
Reply to ronm:
Upon further search...
That is a Roots blower if I ever saw one.
And the turbo version like Cuz's...
Sat, Mar 26, 2016 10:05 AM
Art From De Leon
Reply to ronm:
You would think that A-C would have made a huge point of the engine being super-charged.
I wonder how long after Caterpillar introduced the D-9, before A-C turbocharged their engine, and when did A-C change their construction equipment color from Persian Orange to the pale yellow?
Sat, Mar 26, 2016 11:08 AM
janmeermans
Reply to Art From De Leon:
Art,
I ran a brand new HD 11 in 1968 which had the pale yellow but my uncle owned an orange one that he bought around 1962-3. So my guess is they changed color about '65-66. Also the HD 21s we had in the Seabees and were about "66 or '67 era machines all had turbos. I liked them a lot- way better than the IHC TD 20s that we had.
Jan
Sat, Mar 26, 2016 3:50 PM
rick mckay
Send a private message to rick mckay
Reply to janmeermans:
Art,
Jan
The early hd 16's and 21's used a Buda 844 with a turbo on the 21's to get the extra hp needed. I'm not sure if any were supercharged, but it is possible. They were a Lonova design with the energy cells in the opposite side of the head from the injectors. After AC bought Buda in the early '50's they started calling the engines the 16000 and 21000 engines with few changes except for AC cast on the manifolds instead of Buda. I had a Buda model 6DCS 844 on my sawmill for several years, until it decided to retire. It was a smooth running engine and used about 4 gal/hr on the mill. I replaced it with a 2 valve 671 which burned 2.5 gal/hr and seemed to do a better job. Could be the Woodward governor was just more responsive than the governor on the Buda's Bosch inline pump.
Rick
Sat, Mar 26, 2016 7:41 PM
ronm
Reply to rick mckay:
Rick
Cousin's 21 was the pale yellow, & I don't think it had ever been repainted. I don't know the year, but would guess middle to late 60's, as Jan said.
I do believe it was a 21000 designation, as I remember. We had hell finding main bearings, finally had to send the old shells to a guy in Washington State that rebuilt them.
It also was direct injected, the injectors were inside the valve cover...I remember that clearly, as there was a leaky banjo washer on the return line that immediately started making oil after the overhaul...first oil change came pretty soon. 😛
Sat, Mar 26, 2016 10:01 PM
sdmuleman
Send a private message to sdmuleman
Reply to ronm:
From my book, 'AC Construction & Industrial Equipment" by Norm Swineford,
The 844 Buda type engine was offered NA, supercharged and turboed. This engine is a prechamber type. It appears that the original HD21, 1954-56 used a supercharged 844 engine rated at 235 hp. 56-58 used a turbocharged version of this engine rated at 256 hp. The NA 844 engine was also used in the HD-16 rated at 163/170 hp.
The later 21000 & 16000 series engines are the same 844 CID, but are a complete redesign of the engine to a direct injection cross flow type. the 21000 was used in HD-21 series and was turboed; 16000 & 17000 were used in the HD-16 series and were NA.
Looks like paint colors were a customer option at least in 1960-65.
Sun, Mar 27, 2016 12:14 AM
oldtanker
Send a private message to oldtanker
Reply to sdmuleman:
[quote="jaluhn"]From my book, 'AC Construction & Industrial Equipment" by Norm Swineford,
Looks like paint colors were a customer option at least in 1960-65.[/quote]
OK I was looking for that just because I wanted to know. I do know that they didn't produce a turbo wheel tractor until around 59.
I also know that with the total lack of new under carriage parts for the older HD's I wouldn't touch one.
Rick
Sun, Mar 27, 2016 12:39 AM
ronm
Reply to sdmuleman:
Thanks. I think my AC-nut neighbor has that book, but I've never got to read it.
Sun, Mar 27, 2016 1:14 AM
oldtanker
Reply to ronm:
Well now you can tell the AC nut that you had a guy tell you they were way over rated and most often years behind the competition in their tractor design. Plus they were way to often apt to build something with a high HP rating but massively underbuilt the transmissions.
Rick
Sun, Mar 27, 2016 1:28 AM
