Interesting D4 Transportation Data tag. UCOE
josh
Thank you received: 11
Wed, Sep 17, 2025 11:56 PM
Thank you received: 77
Hi, Josh.
I suspect that those last 2 lines might relate to what is known as 'cubic tonnage' which, IF my understanding is correct, is based on a nominal formula for the weight that can be transported in a given cubic space - as opposed to an irregular space. IF I am right, they have probably taken the length, width and lowest height, 'cubed' them and calculated a nominal weight based on that calculation.
Thu, Sep 18, 2025 12:10 AM
