Interchangeability of hydraulic pump
Showing 1 to 6 of 6 results
Dan1942D4
Send a private message to Dan1942D4
Hello.   Can anyone tell me if the hydraulic pump from an 8U D6 will fit a 7J D4?
Thanks,
Dan G.
Fri, Apr 14, 2023 2:34 AM
GrantJ
I just looked thru my No 44 Hydraulic Control parts book . It shows over 70 configurations. most are for D2 and D4s but it does lists a couple for D6. One configuration from the D6 matches a D4 7J. It is a 37 gallon per minute pump. Many of the D2 and D4 pumps are 25 gallon per minute. My guess is that they are all very similar with different plumbing and valving. Good Luck. Grant.
Fri, Apr 14, 2023 9:18 AM
Dan1942D4
Reply to GrantJ:
Great, thanks for that information, Grant. I will check it out and will provide an update in due course...
Thanks again,
Dan G.
Fri, Apr 14, 2023 10:01 AM
Reply to Dan1942D4:
Thanks again,
Dan G.
Are you referring to #44 pumps? Yes, there were some applications of #44 pumps mounted to "U" series D6's, also D7's and 8's.
More common to the 8/9U's was the #46 pump which would not readily adapt to the D4's
Fri, Apr 14, 2023 11:26 AM
josh
The pump or hydraulic control, if it is a #44 unit may be the same for both machines, there are some applications that show the same pump/hydraulic control, but all the other assocated parts like the mounts, drive shaft assembly, and everything else is different.
Fri, Apr 14, 2023 11:30 AM
sirlleemo
Send a private message to sirlleemo
Reply to josh:
i have a Model 25 laplante-choate pump on my D4 2T and i can not seem to find any information or diagrams anywhere on it. Should i change it out with the 44?
Thu, Nov 9, 2023 1:17 PM
josh
Reply to josh:
We will need more information to answer your question.
What is the problem with the pump/assembly, photos of the pump and complete blade assembly and tractor, any serial numbers on the unit.
Do you have access to a good complete #44 unit for your machine?
Thu, Nov 9, 2023 11:33 PM
