Intake and exhaust valve lash on D337
Showing 1 to 10 of 13 results
CatDW20
Send a private message to CatDW20
I need to adjust the valves on my DW20 with a D337 engine. I have misplaced my service manual and was hoping somebody out there could help me with this.
Thu, Jul 16, 2009 3:31 PM
bruce oz
Thank you received: 22
hello CatDW20 ,has your d337 engine fitted with hydraulic lash adjuster ?
clearance without hyd lash adjusters
-inlet .015''
-exhaust .020''
book i have has no adjustment for with hyd lash adjusters
edit-setting are for serial numbers -
dw20 -57c,67c,87e,88e
engine 37b,38b
dw21-58c,69c,85e,86e
hyd lash adjusters
-exhaust opening 18c bbc
-exhaust closing 4c atc
-inlet opening 6c atc
-inlet closing 20c abc
without hyd adjusters
-reading taking with valve .075'' off seat
exhaust opening 32c bbc
exhaust closing 2c btc
inlet opening 5c atc
inlet closing 9c abc
the c=degrees
information from 1965-66 specification book .
hope this helps ,bruce oz
Thu, Jul 16, 2009 4:00 PM
bruce oz
Reply to bruce oz:
-inlet .015''
-exhaust .020''
engine 37b,38b
hyd lash adjusters
the c=degrees
hello CatDW20, i have a d337 service book for engine 37b1 -38b1 up that i can copy if the info on adjustment if it would help ,bruce oz
Thu, Jul 16, 2009 4:05 PM
SJ
Send a private message to SJ
Reply to bruce oz:
There are two different D337 engines and the early one is just the D337 and the later totally different engine is a D337F so you really need the SN of the machine to get the correct valve settings.The two that Bruce mentioned the 37B and 38B is the later D337F.The F series were turbo charged and the older just D337 were a gear driven roots blower type engine.I,ve rebuilt lots of both the engines but don,t have a spec. for them with the hyd. lifter setting right here and been so many years since I retired I can,t remember the procedure for them.
Thu, Jul 16, 2009 5:40 PM
bruce oz
Reply to SJ:
hello sj ,CatDW20, thank for the info ,i should have put the serial numbers in the post ,
setting in first post are for serial numbers -dw20 -57c,67c,87e,88e and engine 37b,38b
bruce oz
Fri, Jul 17, 2009 5:28 AM
CatDW20
Reply to bruce oz:
bruce oz
Thank you Bruce Oz and SJ for all of your help! I have a DW10 and 5 DW20s! They are the best machines! Don't make them like that any more, do they?
I got onto your website, Bruce and am amazed at everything you have taken pictures of! It would be very helpful to me if you have the specs for the D337.
I have added your site to my favorites and will check it out often!
Thanks again for your help! By the way, the D337 is the 87E model!
Sat, Jul 18, 2009 12:07 PM
bruce oz
Reply to CatDW20:
hello CatDW20,thank you for the ok on the web page ,took heaps of pic of the 22 so i could put it back together again ,lol,
i have 2 books for the d337 ,one book is just the d337 37b1 -38b1 and the service manual for the dw20 and other models that used the engine ,
i am away this weekend ,but will be back home on Monday ,if you post what else you need i will scan them and post,
anything else ?
bruce oz
Sat, Jul 18, 2009 12:21 PM
CatDW20
Reply to bruce oz:
anything else ?
bruce oz
Thanks for the offer, Bruce! I am working on it now and will let you know by the end of the weekend if I need anything else.
I really do appreciate all you help. Do you own alot of CAT equipment? People laugh at me (or hate me) but there is not much of anything but CAT equipment on my property! People know better!! LOL!
Sat, Jul 18, 2009 1:24 PM
bruce oz
Reply to CatDW20:
hello CatDW20, have owned only 2 cat twenty two's ,operator for a few yrs ,in the 80's when there was'nt much work around ,ended up working for Alcoa ,been there 23 yrs now ,just collect cat books now after selling the last 22 a few yrs ago ,its not much cheaper than owning a machine ,i keep buying the power ball tickets 😄 ,but not luck yet ,be a yard full if the winner comes home ,lol, bruce oz
Sat, Jul 18, 2009 1:33 PM
SJ
Reply to bruce oz:
The 87E would have the later D337F engine in it.The 67C is when the 337F was started to be used in them and yours is the later DW20 with the 337F.
Sat, Jul 18, 2009 6:55 PM
bruce oz
Reply to SJ:
hello CatDW20,the d337 with hydrauilic lash ajuster have no settings ,the book says if timing gear timed rigth ,lifters ok.
here are the pages for non hydrauilic lash ajuster and the valve setting for blown and non blown engines ,
[img]http://img24.imageshack.us/img24/3951/d337valvesettings1.th.jpg[/img]
[img]http://img189.imageshack.us/img189/3874/d337valveajustment1.th.jpg[/img]
[img]http://img20.imageshack.us/img20/5416/d337valveajustment2.th.jpg[/img]
[img]http://img24.imageshack.us/img24/3851/d337valveajustment3.th.jpg[/img]
[img]http://img199.imageshack.us/img199/6083/d337valveajustment4.th.jpg[/img]
Mon, Jul 20, 2009 1:59 PM
