installing bevel gear, steering clutchs D-4
Showing 1 to 9 of 9 results
sidehill6600
Send a private message to sidehill6600
I am reinstalling my steering clutchs on my D-4 and in the servicemans book page 61, top of page..says..bevel the edges of cork seals after installations to insure an oil tight seal around bearing cage...looks like to me from the picture ...that all they want you to do is cut off the seal flush to the bearing cap..is this correct or do they mean something else..
on another subject my steering brakes look to be in good shape..however when I was at the cat dealer getting the clutchs put back together a older mechanic walked over and looked at my brake drums and says...those drums are too polished..shiny..etc you need to get them turned. I said what would that do for me...he said it makes them rougher and they work better. I went to Lincoln Brake and Clutch.. and he says..okay I will turned them for you but it wont last long and they will smooth out again. He stated if you wanted better braking action to reline the brake shoes with a braided semi metallic material, which he had in stock. I am not sure of the material of the current pads, but they are not braided and semi-metallic. They have seem to have alot of material left and I hate to reline them for $200...
Sat, Dec 27, 2008 8:28 AM
bob
Send a private message to bob
If you want better friction just sand blast the outer surface of the drums. That will not make them smaller in diameter and will give you max friction.
Be sure to get the bevel gear back on the side it came out of.
Later Bob
Sat, Dec 27, 2008 9:46 AM
Reply to bob:
Later Bob
I got rubber seals from Cat when I installed the crossshaft. seal better than the cork ones.
Sat, Dec 27, 2008 11:12 AM
OzDozer
sidehill6600 - Any work done to roughen up drum surfaces will soon see them rapidly get shiny again. The braided semi-metallic linings do give better grip, but they are more abrasive on the drums.
If the current linings have good lining material thickness (more than 60% of new) .. and are not oil/grease impregnated .. and they have been performing O.K., then stick with them. It's nice to have all new components when compartments are being re-assembled, but it's your call on how much you spend, and how much work you plan on doing.
As a former contractor, I would never hesitate to install new linings of superior quality .. because my tractors worked hard, and the payoff returned quickly. However, for a low-hour-farm-use, or hobby tractor, those linings will likely do you just fine for years to come.
One of the important things to practise amongst your operating skills, is to ensure that you never rest feet on brake pedals, under any circumstances, and use the brakes sparingly.
Constant, repeated, and unnecessarily heavy use of brakes is a guaranteed way of ensuring you'll be back into those brakes again, very soon.
Sat, Dec 27, 2008 1:20 PM
SSsssteamer
Send a private message to SSsssteamer
Reply to OzDozer:
It wasn't long after I relinded my brakes that the right brake band was quickly out of adjustment and about worn out. What had happened a couple of times is that my dog on the parking brake accidentally got engaged while I was using my D4 7U. With my new right brake band about all used up, I dissconnected my parking brake so that wouldn't happen again. When I want a parking brake now, I just drop the blade into the dirt. Am I the only one that has had their parking brake about ruin their right brake band by being accidentally enganged? I use stock Cat brake lining from Caterpillar and they work fine. When I use my winch, with both brake pedals applied, the locked up tracks can be skidded across the ground without using much brake pedal pressure at all. Excellent brakes!
Sat, Dec 27, 2008 2:10 PM
Reply to SSsssteamer:
Had that problem too. But it was a case of 2 operators, I applied the brake and the other guy never did, so he never thought to take it off and never noticed it was on????? until I noticed the smoke coming out of the compartment and stopped him to check.
Brake drums are supposed to be smooth. I would think turning them was only for trueing up an out of round or scored drum.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Sat, Dec 27, 2008 9:00 PM
Oil Slick
Sidehill, I put new bearings and cork seals in the mighty D4 several years ago and still no leaks or problems. Simply lay the cork down first and set the bevel gear assembly in place. Then wrap the cork around the bearing cage and trim the excess off. Use the Cat gasket cement to hold the cork in place because it wants to slip out when you tighten the cover down. Good luck.
Sun, Dec 28, 2008 1:25 AM
sidehill6600
Reply to Oil Slick:
thanks for all the help...got them put in this afternoon...
Mon, Dec 29, 2008 3:30 AM
bernie
Reply to sidehill6600:
Congratulations, did you take any pics along the way?
Tue, Dec 30, 2008 9:49 AM
sidehill6600
Reply to bernie:
sorry bernie...I know you ask me to take pictures before but I have taken any yet..know whats really bad...my wife is the picture queen at my house...thats her big hobby...๐Ÿ˜Š she has so many pictures on this computer I had to buy her an extra harddrive..I will have her take some tomorrow and help me post them on here..soon๐Ÿ˜„
Thu, Jan 1, 2009 9:57 AM
