My engine inspection covers on my 30 all seeped oil from the bottom of the cover. The gaskets were old and a paper type that had become brittle. I bought new gaskets from Olson's. These were cork/neoprene and .060 thick. They would be easy to make except for the size. I would have to buy a lot of material to make them. The four cost around $48 delivered to my door.
My first attempt to reseal failed and the cover continued to seep long after the tractor had stopped running. The design of this cover leaves about 3/4 of an inch of a ledge for the oil to sit on after the engine stops. This is made up from the edge of the cover, the gasket, and the thickness of the block itself. I simply used gasket cinch to glue the gasket to the cover and then placed the cover in position.
My second attempt was similar except I used silicone on the other side of the gasket where it would meet the block. I also put silicone in position on the bottom edge of the cover to keep oil from sitting there. See first pic.
I am aware of the possibility of the silicone coming off and clogging my suction screen. This screen is a large cup with wire mesh that will easily handle some stray silicone. I am going to keep my eye on it.
Has anyone else experienced this problem and if so, what are the solutions? I have not run the engine after the second attempt. Thanks, G
