injection pump
injection pump
jwwelty
Send a private message to jwwelty
does anybody have any info on checking the pump height on a d318 in a d6 9u. I know there are specs just dont have them. And whats the difference between d6 and no12 grader specs? If i can get some good instructions i will take pics of the process so we can put it in the diesel info area.
thanks
Fri, Nov 25, 2016 9:29 PM
1.736" from the top flat surface of the housing down into the bottom of the yoke where the plunger seats.
All D318, D315 etc are the same.
Measure at TDC on compression stroke. the lifter will continue to rise as the engine rotates past TDC.
SJ used to recommend decreasing the setting to compensate for any measurable wear on pump plunger length and lifter yoke bearing surface. Plunger length is 2.6575-2.6577 max wear of 0.005"
Fri, Nov 25, 2016 9:51 PM
sdmuleman
Send a private message to sdmuleman
I have the D318 & D6 serviceman's reference and the rack setting charts in pdf; pm me your email and I'll send them to you.
Sat, Nov 26, 2016 11:21 AM
| Kingaroy, Queensland
