info 0n spec chart d3400_15
novavalleycat
Send a private message to novavalleycat
Attention Old Magnet I am trying locate the spec chart for the 3415 caterpillar gen set would it be possible for you to post this info if you could i would appreciate it very much
Fri, Apr 4, 2025 1:19 AM
Thank you received: 63
Sorry, I no longer have that info, it was lost when "imageshack" crashed years ago.
Fri, Apr 4, 2025 7:25 PM
novavalleycat
Thanks. I did find where someone here posted about an article about the D3400. Sent a request off to the Cat visitor centre to see if they can help.
Sat, Apr 5, 2025 4:21 PM
Thank you received: 76
The only item I have is this which is not much use:
Sat, Apr 5, 2025 10:09 PM
novavalleycat
Thanks. The visitors center recommended contacting the archives at Cat.
Sat, Apr 12, 2025 12:33 PM
