In need of clutch parts for 977H 53A2453
Showing 1 to 7 of 7 results
Mustangrh68
Send a private message to Mustangrh68
Found the inner drum cracked at clutch shaft spline.
Need part number 7M2928 or 7M2929, or complete assy which ever.
Or a complete upgraded clutch assembly with the 7M5001/2 splined inner clutch drum.
But need it complete as will need the pressure plate and the whole works.)
Looks like there is a large selection of units that are compatible with these!
(Use the same clutch shaft, just need to find one! LOL)
John Parks and I are trying to put something together!
Thanks for the help in advance.
Rob.
Fri, Jun 26, 2020 5:13 AM
Mustangrh68
Here are the units that have the compatible input shafts and are a possible donor tractor!
10A1-1616
17A1-19442
20A1-4222
21A1-331
37A1 and up
44A1 and up
53A1-8886
62A1 and up
81H1 and up
82H1 and up
83H1 and up
84H1 and up
85H1 and up
7M4372-9999
4R613-3633
5R854-5515
3T1-28058
4T1-9999
6T1-1054
8U1-11045
9U1-29764
Any help would be greatly appreciated!!
Sat, Jun 27, 2020 10:33 PM
Reply to Mustangrh68:
10A1-1616
17A1-19442
20A1-4222
21A1-331
37A1 and up
44A1 and up
53A1-8886
62A1 and up
81H1 and up
82H1 and up
83H1 and up
84H1 and up
85H1 and up
7M4372-9999
4R613-3633
5R854-5515
3T1-28058
4T1-9999
6T1-1054
8U1-11045
9U1-29764
Places on Machinery Trader Parts search show some places having the 7F5001-2
Sat, Jun 27, 2020 10:43 PM
Mustangrh68
I checked but with the 5001/2 I need the outer drum/pressure plate to go with it!
I haven't found that yet. John has the drum but not the pressure plate.
That is why I am looking for other parts as well.
Thanks.
Sat, Jun 27, 2020 11:38 PM
gemdozer
Thank you received: 25
Thanks.
I check tomorrow for the stering cluch drum and the pressure plate
Sun, Jun 28, 2020 8:29 AM
gemdozer
Reply to gemdozer:
I check this morning and have 1 drumm 7m5001 and 7m5002 and am tinking a plate 9m2201 and 7b5190 but I recheck tomorrow in my second shop if am still have some
Mon, Jun 29, 2020 2:18 AM
Mustangrh68
Reply to gemdozer:
Awesome to hear! I also found a couple of D6 9U's maybe for parts. Might be able to interchange pieces!
Send me a PM if you have for sure. Would be looking for discs and steels if you have them as well!
Thanks, Rob.
Mon, Jun 29, 2020 10:09 PM
gemdozer
Thanks, Rob.
I recheck this morning and have a drum 7b5294 and a plate 7b5190 from d6 37a and have some discs and plates in good condition
Mon, Jun 29, 2020 11:24 PM
