im back! and going to need some info in the next couple months!
Showing 1 to 10 of 11 results
lil cat mec
Send a private message to lil cat mec
I'm over here in Portland OR, for the next two months for college, well caterpillar classes. just today I have talked to two farmers and have found 2 d9's, I believe both are 18a's, 1 d7 3t (he claims) and a d6 9u. the 9u and 3t shouldn't be much, just haven't ran in 5 or so years, going to check all compartments, clean carb if there is any fuel in them.. then try and fire it up, maybe file points in the mag... same goes for one of the 18a's but its been sitting for about 12 years... then the last 18a has the nose taken off and the front mount cable unit.. he said he got it rebuilt and never got to putting it back on. neither of them remember where their manuals are.... so I may need some help from you guys if that's okay.. feels great to finally have a reason to post again and finally working on some true old iron not just d6c's etc... haha
Hope everyone's been doing good and staying out of trouble..
I will be down in Petaluma CA for the 4th of July working with Jr Ponte for the weekend hope to see some people while I'm down there (7uPuller)
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Fri, May 27, 2016 7:50 AM
7upuller
Hey LilCatMec,
Good to hear from you... I just bought 2 D9's. One is a 18-a. I need an undercarriage. Take pictures of what you've got and post here for me. The other one is a D9e/49a. It's a great tractor. Rd4 is still waiting for you...
Glen
Fri, May 27, 2016 8:18 AM
caterpillar13
Reply to 7upuller:
Hey LilCatMec,
Glen
hi
where are the cats located. im in hillsboro and interested in 1 of the d9
Fri, May 27, 2016 11:32 AM
lil cat mec
Reply to caterpillar13:
hi
Come to find out the one that needs the nose put together is a d8 14a, im on suavie Island, none are for sale, the gentleman just wants me to get them running again, glen i may be bringing a tandam axle gooseneck, if so im wondering if ill need at least a trip permit to haul it back?
1935 CAT 22 2F4455W
Fri, May 27, 2016 11:39 PM
lil cat mec
Reply to lil cat mec:
got the d6 9u fired up after pulling the starter and cleaning it up, the Bendix would not return..
got the pony fired up on the d8 18a, but it kept running out of fuel/power before the main engine would fire, pulled the carb and didn't find anything that made me think it was the issue. cleaned the sediment bowl and opened the fuel shutoff with the sediment bowl off and there wasn't enough fuel to keep a straight stream. so I pulled the tank off (there was a lot of rust in the tank) and pressure washed it out, created a couple pin holes. so I jb welded it so I can get it running tomorrow. (were going to use por15 just wanting to make a quick fix for now)
the d7 17a is another story, pulled the carb because its overflowing through the up pipe, reassembled it, and its doing the same thing, tomorrow I'm going to pull it back off and check the float level.. the gearbox for the pony to main motor has milky fluid so I'm going to flush it, and I'm also not getting spark. going to pull the cap off and sand the points and see if she will throw a spark..
and I may be getting a 1466 IH for doing the easy work of getting these running again and putting them back together...
that's all I have for now!
1935 CAT 22 2F4455W
Sat, May 28, 2016 8:25 AM
lil cat mec
What weight oil does that gearbox take? 80-90wt?
1935 CAT 22 2F4455W
Sat, May 28, 2016 10:39 AM
gemdozer
Thank you received: 25
The gear box use 80x90 oil
Sat, May 28, 2016 3:54 PM
mog5858
Reply to gemdozer:
well sounds like better than spring brake lol. well take lost of pic for us sound like your going to have a good summer. good luck
Sat, May 28, 2016 8:17 PM
lil cat mec
Reply to mog5858:
Yes it is! He has a couple international wherl tractors im messing with, some implements im repairing. I dont know if im going to want to go to school during the week haha
1935 CAT 22 2F4455W
Sun, May 29, 2016 1:21 AM
lil cat mec
D7 17a finally has spark!!
1935 CAT 22 2F4455W
Sun, May 29, 2016 2:30 AM
lil cat mec
1935 CAT 22 2F4455W
Sun, May 29, 2016 12:59 PM
