IH toolbar crawler stoled from red power board
Showing 1 to 10 of 10 results
ag-mike
mrsmackpaul
uncommon as in IH or as in on a TD 9 or as in the arrangement of the tool bar ????
Paul
Tue, Aug 9, 2016 6:44 PM
old-iron-habit
Reply to mrsmackpaul:
Paul
I'm thinking as in toolbar. Lots of TD9s around.
Wed, Aug 10, 2016 12:57 AM
ag-mike
Reply to old-iron-habit:
yes actually the ih manufactured toolbar/toolbar blade set up is very uncommon for any the ih crawlers. case and allis also had toolbar set ups for their crawlers. i ain't never seen any those 2 though. besides cat, i have a small collection of other tracked machine manufacturers toolbar brochures.
Wed, Aug 10, 2016 4:10 AM
mrsmackpaul
Reply to ag-mike:
If it is of interest I have some stuff on IH tool bars sold out here I scan and put up if you would like
Paul
Wed, Aug 10, 2016 7:25 AM
TOGNOT
Paul
Well that's great news is I understand you correctly. Does that make my TD15 really rare ?
[attachment=37349]image.jpg[/attachment]
Wed, Aug 10, 2016 1:16 PM
old-iron-habit
Reply to TOGNOT:
[quote="TOGNOT"]Well that's great news is I understand you correctly. Does that make my TD15 really rare ?
[/quote]
I may be seeing it wrong but it looks like a common blade to me. On a toolbar the blade arms and cylinders would pivot to the back so a toolbar could be attached behind the machine.
Wed, Aug 10, 2016 5:08 PM
[/quote]
Like both tractors are capable of having the frames swapped front to back? The TD9 doesn't show the toolbar connection point but the TD15 looks like you would back into the frame and just flip the cylinders over as it has slide bars on the rear of the track frames.
Wed, Aug 10, 2016 6:26 PM
old-iron-habit
Reply to drujinin:
I did see the rear guides, but was looking for hinges. I figured a complete toolbar or other attachment could use the trunnions and cylinders. Probably a lot easier to drop the whole dozer than dropping just the blade and spinning the arms..
Wed, Aug 10, 2016 7:22 PM
ag-mike
cat are the only swing around draft beams i know of. though cat did have a disconnect and back tractor into t-bars too. i believe these were early arrangements. all other manufacturers were disconnect and back into setups i know of.
Wed, Aug 10, 2016 9:39 PM
TOGNOT
Reply to ag-mike:
Yes, on the TD 15 you remove two bolts on each side, pull the pins on the hydraulic cylinders and back away, leaving the blade on the ground.
Oilslick has not found me any tool bars to attach in the back, so I have not tried it yet.
Wed, Aug 10, 2016 10:57 PM
| Hartley - South Australia
Newby Hall Tractor Fest
